Tekin Redline physical timing
clockwise is 0 counter is 24 see pic in link
http://www.teamtekin.com/product%20p...f-Sensored.jpg
Good Luck
Timing
on the end bell just past the 12 on the timing sticker.
Now if you wont 0 timing lossen the three screws on the end bell & move the end bell
clock wise till the notch is at 0 timing not 12...
Cheers Daz
Just a bad angle of picture. Look at your Redline You'll see the notch clearly on the endbell.
So in the picture the motor has a timing of 12 degrees? That is how mine looked. I loosened the screws and rotated in clockwise so the notch is now at zero. I was trying to take a picture to show this, but camera would not work. Do all Tekin motors have a set timing when you buy it? Why is this? Thanks.
