Old 11-07-2009, 08:02 PM   #1
Trader Rating: 20 (100%+)
Default Tekin Redline physical timing
How do you know what the motor timing is by looking at the motor itself. I have not touched the motor so is it at 0? I see degree markings on the motor, but not sure how to read it.
storytyme is offline   Reply With Quote
Old 11-07-2009, 08:50 PM   #2
20 SMOKE's Avatar
Trader Rating: 101 (100%+)
clockwise is 0 counter is 24 see pic in link
http://www.teamtekin.com/product%20p...f-Sensored.jpg
Jamie W
*Team Tekin*Tekno-rc*DE Racing*AKA*DDHRC*
20 SMOKE is offline   Reply With Quote
Old 11-07-2009, 09:04 PM   #3
I am not quite understanding. What is the timing of that motor in the picture? How do I make sure it is at 0 degrees? Thanks for your help.
Old 11-07-2009, 09:15 PM   #4
20 SMOKE's Avatar
does it have a sticker for the timing
Jamie W
Old 11-07-2009, 09:21 PM   #5
Geezatec's Avatar
The endbell there is a notch, it will tell you. i.e. my 2.5 Redline is set at approximately one graduation left of +12. Each graduation would be appoximately 4 degree. My Redline is set at 4 graduations from 0deg, = 16deg from 0. That how I understand the graduayion on timing.
Good Luck
Geezatec is offline   Reply With Quote
Old 11-07-2009, 09:38 PM   #6
Jazza's Avatar
Trader Rating: 16 (100%+)
Default Timing
Storytyme, look at the link....there is a mark
on the end bell just past the 12 on the timing sticker.
Now if you wont 0 timing lossen the three screws on the end bell & move the end bell
clock wise till the notch is at 0 timing not 12...
Cheers Daz
Jazza is offline   Reply With Quote
Old 11-07-2009, 09:45 PM   #7
Geezatec's Avatar
Just a bad angle of picture. Look at your Redline You'll see the notch clearly on the endbell.
Old 11-07-2009, 10:30 PM   #8
So in the picture the motor has a timing of 12 degrees? That is how mine looked. I loosened the screws and rotated in clockwise so the notch is now at zero. I was trying to take a picture to show this, but camera would not work. Do all Tekin motors have a set timing when you buy it? Why is this? Thanks.
Old 11-07-2009, 11:40 PM   #9
Geezatec's Avatar
Leave it to where it was. Approximatey +16deg. I beleve all sensored motor are adjusted there factory default. You can experiment with it, just make note where is was. Many Tekin RS & RSPro uses Hotwire. Useing LED's on RS/RSPro & R1 series 7-14 increments of adjustments, useing hotwire, fine tuning are done. Then again, you're not useing RS/RSPro, you'd adjust the mechanical way. Useing Hotwire you can adjust the timing though it.
Tekin RS ESC sensored Jeff Cuffs Electric On-Road 23359 10-02-2016 06:57 AM
Tekin Redline RS Sensored ESC and motors, opinions for offroad? Cain Electric Off-Road 4230 06-07-2015 04:38 PM
tekin RS question BSS07 Electric Off-Road 36 01-16-2009 01:31 PM
