Xray T1
Originally Posted by cheehtae
Hey guys I need some help, will the FKo4 front shock tower fit the T1 Raycers bulkhead?
LMK and all the help I can get will be greatly appreciated/
i think im gonna go run in front of a bus and im sorry for clogging this thread
youll kno why in a minute
so today i go to try once again to thread these buggers
and im reading the instructions cuz i was double checking the length right
and its like note: one side has CW thread and other CCW and BING the light went off in my head, after that it was a breeze
learning from this first kit
i tell ya
gosh im a moron
i tell ya
gosh im a moron
i wont be offended by n00b or other various negative remarks
im glad ppl will get a laugh out of this maybe
anyways
the kit is finally pretty much done (other than the shocks which im going to have someone do for me) but upon making the servo saver i jacked up a ball cup so i improvised with a ball joint and i made sure it was still at the 57mm length as is the other side and i think this might be the problem but the servo saver is rubbing the bulkhead in the right side, the side with the cut out, maybe i measured poorly and they arent 57mm or something but i cant figure it out, and also just by like spot hooking them to the balls it appears the wheels are not going to be straight either so idk
is there anyone here that feels the FK04 is better that the FK05? or is the FK05 that much better than the FK04? just curious.
FK
To answer in short, yes the 05 is better than the 04, why else would xray bring it out???
It seems to many that the FK 05 is a much more stable on the track than the 04, it is more predictable, has a lower CG, and appparently better drive efficieny, although the 04 still has one of the best out there.
The other thing, out of the box the 04 will beat the 05, but dial up the 05 and say bye bye to the 04.
Regards, DIMO
motor screws
Just got my Xray 04 Friday! But the thing is i dont have any screws to keep the motor in? Which screws do i use for this/>?
I can still hold my own with my 04FK,I race on a 40 x 80 carpet track and I do beat my share of 05FK's.I do have a few hop ups on my Xray,BMI 350 chassis,alum. hubs front and rear.It rocks on carpet with foams and i dont think a car can be any more stable..I guess it could be but i dont think it matters..
its nice
i have a T1. it treats me pretty good.
power slides
I run a T1 x-ray. ive been running on indoor asfault. alot of traction and air conditioning. it some tight turns the ass end slides out. can anyone offer some advice?
...the kit is finally pretty much done (other than the shocks which im going to have someone do for me) but upon making the servo saver i jacked up a ball cup so i improvised with a ball joint and i made sure it was still at the 57mm length as is the other side and i think this might be the problem but the servo saver is rubbing the bulkhead in the right side, the side with the cut out, maybe i measured poorly and they arent 57mm or something but i cant figure it out, and also just by like spot hooking them to the balls it appears the wheels are not going to be straight either so idk
http://www.teamxray.com/xforum/viewtopic.php?t=602
