Xray T1
#7306
Originally posted by theisgroup
you will need 2 set of the 302040. and then cut one of the 302053 in half, or you can purchase 2 more of the 302032. you will also have to cut the hinge pins down
the solution on the servo mount:
a) don't use the botton hole of the servo where it hits the arm mount
b) if you look at the factory team instructions. the arm mount on the servo side has the t1r mount, where the screw taps into the mount and not an aluminium retainer.
#7307
Originally posted by c-lyon
Neil Rabara, I have had the same receiver as T-Bag-R for a year with no problems. Do you mean there is an inherent problem with synth receivers, or just with JR, or ???
Thanks for your help.
#7310
Originally posted by AdR|aN
Hi guys. Need some help here.
This question is posted many gazillion times but i cant seem to find it. So if anyone wouldnt mind me asking again, here goes.
I am still running with T1 EVO2 FOC. I would like to convert to short arms soon and was wondering wat else do i need? Other then the short arms of cos.
ANother question is, previously ppl had problem with the servo mounting which is obstructing the front arm. Anyone had a solution to this?
Don flame me for asking it again but i seriously gave up trying to look a few pages back.
TIA
TIA
#7311
Neil, Thanks so much for you advice. Like I said before it has been about 15 years since I have picked up a transmiter. If the internet was around then I might be a factory team driver. I have a Kyosho Ultima Pro that I could not get rid of the glitching problems. I took it to 3 hobby shops where I used to live and thy were as dumb founded as I was. Don't mean to gush but, Thanks Man
#7312
#7313
Hi guys,
this past week-end i have raced my Xray FK for the second time....and my car was on rail!! where i race we have one really fast racer who run an HPI pro4...a lot of racer say if you can beat him...it s because your car is really good!! we run on carpet with stock motors!! for me it was a really good challenge.....
guess what....my xray was able to win the main and set the fastest lap at every round of qualification and in the main too!! i have miss the TQ by .5 of a seconde but in my best qualification i have a wreck with a lap car that it cost me around 2 secondes!! i think it s not so bad!!
i feel so good about this car!!
Pace
Pace
#7314
Good job Pace. It's great to see enthusiasm like that. The trick is to go faster.
#7315
Trace Racing-
I can answer for greg as i filled out the setups on my tsn while he was writing his race report. The problem is the notes section on mytsn isnt big enough to write it all out.
Greg and I measure our droop by removing the wheels from the car and placing the car flat on a tweak board or flat surface.
next make sure none of the screws are sticking out the bottom of the chassis (they shouldnt be but double check) and also watch out for the front lower bumper sits slightly below the chassis so set the car so the front lower bumper barely hangs off the edge of your board.
next grab your ride height guage and slide it under the arm by the outer hinge pin.
if you are running kick up or anti squat make sure to measure from the lowest point on the arm.
or if you have a droop guage like the yokomo 2n1 ride height droop guage or the losi droop guage you can measure from the bottom of the chassis to the same place on the arm and it will read the same but I reccomend having the car on a flat surface to make sure its as equal as possible.
As far as anti squat adding more anti squat or more angle will give your car more on power traction but will also make it push on power exiting the corner.
greg like low roll center in the rear with 0 squat and i liked mid roll center with 0 squat
and in front we both ran mid roll center but i ran 1.5 degrees of kick.
hope that helped.
hope that helped.
#7316
I have a question relating to droop that may have been asked before. The setup book that came with the FOC edition recommends droop settings for the pillow ball setup. Should this change for the C hub suspension and are the droop settings different if you use short arms?
#7317
droop is droop it just comes down to where you measure it at from my racing experience its good to get comfertable with your way of doing it and stick with that way. so it is easier for you and more comfterable feeling known that you do it the same way all the time.
as far as long/short arm = no its the same but with pillowball it depends where you measure from.
hope that helps
hope that helps
#7318
#7319
#7320
Hi, I'm still running the PB suspension on the first T1. I'm contemplating on converting to the short-arm C Hub suspension too but due to the cost involved, I plan to convert in stages. Our LHS don't have the conversion kit (somebody mentioned it here).
I plan to convert first the front end. From PB to the short arm C hub. Rear will remain on PB for the meantime. What kind of improvement can I expect?
I really appreciate the steering the PB + one way I currently have. I still doubt that it can get better still but I want to try anyway. This is the only car I've driven which responds to minute steering corrections into the corners. If the Chubs can improve on that then convert I will. I already have the front shock tower for the C-hub conversion as well as the oneway, 1.77 ratio pulleys, solid layshaft.
If I do convert totally to short arms, how (scale of 1-10, 10 being that of the FK) will my old T1 compare with the FK?
