what should i upgrade my traxxas rustler with?
HI i have a electric rustler with a stock brush motor, and it does not have a electronic speed control just put a 20 tooth gear on it and got more speed but what else can i do?:confused:
ttt
One of the best things you could do is upgrade to a brushless systems. You'll get more run time and tons of speed and torque. If that is outside your budget then a ESC is a must. You'll gain run time. After that it's pretty much up to you. If you feel your truck needs stronger A-arms or better ball bearings. It also depends on what you want to do with your truck. If it's race then you'll want to add parts that are lighter and offer better handling, including batteries, motor, tires. Or if your bashing around where ever you feel like running then strength may be a concern.
I agree.
If you can afford it then this is a low cost option that will give you more speed and runtime. http://cgi.ebay.com/eZrun-RC-1-10-12...item19b300db51 If thats out of the question then this is a lower cost option. http://www3.towerhobbies.com/cgi-bin...?&I=LXAXT7&P=0 Keep in mind you will likely want to upgrade this eventually also, but it will give you increased runtime and maybe a bit more speed. If you have the older model with mechanical speed control it likely has bushings as well. Upgrading to bearings will also give you more speed and runtime. Here is a low cost set. http://www3.towerhobbies.com/cgi-bin...?&I=LXD050&P=7 If you do not have a few good batteries then that is another thing you should look into. Not sure what you have but dont buy anything less than 3000mah if you want to run long enough to have fun. Many folks on here have upgraded Rustlers, including myself. So Im sure you will get lots of responses. |
Originally Posted by burnineyes
(Post 6470686)
