Tekin RS ESC Set-up thread >
Old 09-09-2009, 08:09 PM
  #31
Default RS + Novak 21.5
Anyone have any setup sheets for an RS combined with a Novak 21.5 Ballistic or SS? Looking to set up for indoor carpet if anyone can help me out.
clunker is offline
Old 09-10-2009, 04:16 AM
  #32
amnesia's Avatar
Hi,
Does anyone have any recommendations for running a 13.5t Speed Passion in a Photon on rubber on a short, twisty carpet track (7 second laps). I was running FDR of 5.4 on my of speedy... looking for V200 settings on my new RS Pro.
Cheers,
Daniel.
amnesia is offline
Old 09-10-2009, 02:34 PM
  #33
Trader Rating: 17 (100%+)
Default oval set ups
where do we see the rsults and settings for oval?
Originally Posted by dynodan22
I think you will see some more set ups for 17.5 in a few weeks.
I am running the RS with a 17.5 hacker e40 motor, but offroad doesn't
start for a few weeks we are just finishing oval. I know a few guys at our
track for onroad tc 17.5 will be running it. I am not sure how many others
are running it for offroad yet.
Dynodan22
markny is offline
Old 09-10-2009, 03:06 PM
  #34
Trader Rating: 21 (100%+)
Hobbytalk.com
lidebt2 is offline
Old 09-10-2009, 05:13 PM
  #35
mjc168's Avatar
Trader Rating: 25 (100%+)
Originally Posted by liljohn1064
Start at 6.5 and work your way towards 6 at small increments.
Currently I am gearing at 6.4 FDR.... amazing, how can i believe that...its tones of torque + speed....thanks liljohn1064
I will try 6.6FDR this weekend
mjc168 is offline
Old 09-11-2009, 09:09 PM
  #36
magee's Avatar
Default tekin esc
looking for a setup ss 21.5 VTA setup hotbody S 96 spur 56 pinion 5000 mah 7.4v 35c lipo iam getting the tekin rs this week on order right now iam running lrp esc need more power out of the spec 21.5 novak ss please help this is a whole nother world from nitro thanks
magee is offline
Old 09-21-2009, 03:16 PM
  #37
Anyone? Preferably a setup that leaves motor timing as is and just adjusts through the RS.
clunker is offline
Old 09-21-2009, 07:47 PM
  #38
liljohn1064's Avatar
try a 5.2 FDR, 20* boost, no turbo, don't touch the motor.
liljohn1064 is offline
Old 10-23-2009, 07:29 PM
  #39
ziggy355's Avatar
Default need help
Hey guys, just wondering if anyone can give me some advice. I am running a 8.5 RS pro system in my Hotbodies D4. My gearing is 25/80 and all my setting are all normal. I am trying to get the v200 but cant find it. Anyways my problem is that I started with a 16/80 gearing and it worked ok and the motor never came off that hot at all but I had no power. So I started to gear it taller. I tried a 18/80 then 20/80 the 23/80 and now 25/80. now the 25/80 gives me the ppower I want but the motors gets way to hot and I need some advice on maybe how to setup my esc??? Any help would be great guys....thanks..
Louie
ziggy355 is offline
Old 11-28-2009, 11:17 AM
  #40
Track surface Carpet
Traction (h/m/l) H
Size (s/m/l) S
Class 1:18 MOD
Chassis LRP Shark (CF)
ESC Tekin RS (stupid question?)
Motor Novak three-80
Gearing 12/49
Battery Turnigy 2200mah 25C
Firmware 200
Drag brake no
Brake 100
Limiter no
Neutral narrow
Volt cut off 6.22v
Motor type Brushless FW/BR
Throttle profile 5
Sensored/dual SENS
Timing advance 2
Turbo boost MAX
Turbo delay 0.2
Note: Had some serious issuses with FW 180, since i changed to FW 200 im never getting rid of my RS
xyllian is offline
Old 11-28-2009, 11:59 AM
  #41
Default 17.5 novak ss
anyone got setup for novak 17.5 ss motor?
1/10 sedan on a 180 ft straight. thanks
boybawang is offline
Old 11-28-2009, 12:49 PM
  #42
set up wanted for f104 with 21.5 epic motor on carpet
Titanum28 is offline
Old 11-28-2009, 02:52 PM
  #43
rack's Avatar
Trader Rating: 68 (100%+)
Originally Posted by Randy_Pike
I'd like to reccomend our editable setup pdf sheet for this thread. It has a notes section and is easy to fill out, save and post:
http://www.teamtekin.com/graphics/se...p-sheet-v1.pdf
Does anybody have a 1/12 setup for carpet 1cell motor 17.5 dou 2 medium size track.
rack is offline
Old 12-05-2009, 07:00 PM
  #44
LOW ET's Avatar
Trader Rating: 109 (100%+)
since i'm not going to join facebook just to see some setups, does anyone have a 13.5 wgt setup for a track like this, 90'X40'
using v200 software, 1s lipo, lrp x11 or x12 13.5 and 53.5mm tires. gearing and esc profile would be great.
what setups were the tekin guys running in 13.5 wgt at the classic and indoor champs?
LOW ET is offline
Old 12-05-2009, 09:17 PM
  #45
Super Moderator
J.Whiting's Avatar
Location: a very small town in wisconsin that is in the middle of absolutely no where
Trader Rating: 63 (100%+)
here is mine from rc performance in madison wi....
Track surface ozite carpet
Traction (h/m/l) medium
Size (s/m/l) s/m 75x60
Class 13.5 sedan
Chassis corally 09
ESC rs
Motor 13.5 duo
Motor timing 10
Gearing 34/104=6.12
Battery 5000 40c
Firmware v200
Drag brake 0
Brake 100
Limiter 0
Neutral 16
Volt cut off 6v
Motor type fwrd only
Throttle profile 4 or 5 depends on traction
Sensored/dual sensored
Timing advance motor 10
Push control 0
Timing boost 15
Turbo boost max
Turbo delay .3
car is 3-5 tenths faster that the rest of the guys at my track. good power out of the corners and very good straightaway speed.......... 17.5 is about the same but gearing is 41/98=4.78.............jeremy
J.Whiting is offline
