Old 08-13-2009, 12:59 AM   #1
Default Tekin RS ESC Set-up thread
Since the introduction of 200, the RS thread is going bonkers! I figured it would be worth while to have a thread just for RS set-ups. The other thread is great for questions and queries/problems (which Randy and Co and handling amazingly), this one is ONLY for set-up's and relative feedback.
So, copy and paste the following list and add your details, to let everyone know your current HOT set-up. If you're not a grinch that is
Or, tell me this idea is arse, and scan the last 30 pages of the other thread looking for a set-up
Track surface
Traction (h/m/l)
Size (s/m/l)
Class
Chassis
ESC
Motor
Motor timing
Gearing
Battery
Firmware
Drag brake
Brake
Limiter
Neutral
Volt cut off
Motor type
Throttle profile
Sensored/dual
Timing advance
Push control
Timing boost
Turbo boost
Turbo delay
JR007 is offline   Reply With Quote
Old 08-13-2009, 06:35 AM   #2
Fuzzy's Avatar
I'll second this motion. I think this would be a helpful thread.
Fuzzy is offline   Reply With Quote
Old 08-13-2009, 06:44 AM   #3
Very good initiative.....let me start.
Track surface: asphalt
Traction (h/m/l): high
Size (s/m/l) : very large
Class 13.5
Chassis Tamiya 416
ESC RS Pro
Motor Fantom 13.5
Motor timing 0
Gearing 69/35 (4.05 FDR)
Battery fantom 5000 40c LiPo
Firmware 200
Drag brake 0
Brake 100
Limiter
Neutral 8
Volt cut off 2s
Motor type BL/FW
Throttle profile 5
Sensored/dual Sensored
Timing advance max
Push control 0
Timing boost
Turbo boost max
Turbo delay 0.7
Note: Motor cooling is essential (LRP has good solution), fastest laptime on the track and top speed (84km/h 52mls/h)
_____________________________________________
Tamiya TRF 417, Fantom Racing
rcpoint is offline   Reply With Quote
Old 08-13-2009, 07:19 AM   #4
razzor's Avatar
Track surface = Asphalt/slurry
Traction (h/m/l) = m
Size (s/m/l) = l +- 260m +- 50m straight
Class = 13.5
Chassis = TOP Racing Scythe
ESC = RS Pro
Motor = SP 13.5
Motor timing = stock - 12deg
Gearing = 45mm roll out - 62mm tyres - 1.94 int/ratio
Battery = Chargery 5200mah 25c
Firmware = 199
Drag brake = 40
Brake = max
Limiter = max
Neutral = 10
Volt cut off = 3.2
Motor type = bl/fw
Throttle profile = 4
Sensored/dual = sensored
Timing advance
Push control = o
Timing boost = 16
Turbo boost = max
Turbo delay = .6
Motor runs around 55 deg/c on day +- 25 deg/c ambient temp
Excellent punch and mid with good top end.
Will run 200 this coming weekend.
Casterracing ZX1.5R
casterracing EX-1 Pro, SP Silver Arrow
TOP Racing Scythe, SP 17.5, SP GT Pro 2.0
TOP Racing Scythe, SP 4.5 V2, Hobbywing Xerun 120SD 2.0
TOP Racing Scythe, SP 13.5, Hobbywing Xerun 120SD 2.0
razzor is offline   Reply With Quote
Old 08-13-2009, 07:31 AM   #5
liljohn1064's Avatar
Trader Rating: 17 (100%+)
First Test setup for 17.5 Redline:
Track surface: Carpet
Traction (h/m/l): H
Size (s/m/l): S/M
Class : 17.5 Rubber TC
Chassis : JRX-S Type R
ESC : RS
Motor : Redline 17.5
Motor timing : 0*
Gearing : 118/43 FDR of 5.0
Battery : Trackpower 4900 25C
Firmware : 200
Drag brake :55
Brake : 85
Limiter : NA
Neutral : 10
Volt cut off : 6 Volts
Motor type : Brushless/Forward
Throttle profile : 4
Sensored/dual : Sensored
Timing advance :
Push control : Off
Timing boost : 20
Turbo boost : Off until final gearing is achieved
Turbo delay : .5
John Higgins former student of The Ian Ruggles Negative Reinforcement Driving School. The "Team Principal".
liljohn1064 is offline   Reply With Quote
Old 08-13-2009, 09:17 AM   #6
Team Tekin
Randy_Pike's Avatar
Send a message via Yahoo to Randy_Pike
I'd like to reccomend our editable setup pdf sheet for this thread. It has a notes section and is easy to fill out, save and post:
http://www.teamtekin.com/graphics/se...p-sheet-v1.pdf
"Things may come to those who wait, but only the things left by those who hustle." Abraham Lincoln
Tekin,Protek,A-Main Hobbies,JConcepts,Avid RC,Yokomo,MIP,SikLidz,FactoryRC, www.randypikerc.com
Randy_Pike is offline   Reply With Quote
Old 08-13-2009, 09:28 AM   #7
HarryN's Avatar
Send a message via AIM to HarryN
Good idea indeed!
And Randy, thanks again for that editable PDF setup sheet! TEKIN F-ing RULES!! Managers like you do companies well.
Track surface - Asphalt
Traction (h/m/l) - low (dusty at the moment)
Size (s/m/l) - LARGE (110' x 50')
Class - 10th scale Mini (203 - 208 wheelbase)
Chassis - ABC Hobby Genetic
ESC - Tekin RS Pro
Motor - Tekin Redline 17.5
Motor timing - Factory (12 degrees)
Gearing - 2.7:1
Battery - Thunder Power 4300 MAh 25C, 2S
Firmware - Version 200
Drag brake - 0
Brake - 100%
Limiter - 0
Neutral - 3
Volt cut off - 2S Lipo configuration, LED 3??
Motor type - Brushless
Throttle profile - LED 4, Agressive, Low End
Sensored/dual - Sensored
Timing advance - +12
Push control - 10
Timing boost - 5
Turbo boost - 10
Turbo delay - .7 (technical track setup)
I am still doing some adjustments and I may have to go back to the Linear configuration for my throttle profile. The Turbo is having some issues with the Agressive Low End (LED 4) setup.
Car(s): Team Losi 22 1/10 Buggy, Team Losi 22 1/10 Stadium Truck
Motors/Engines: SP 13.5 v1.0, SP 17.5 v3.0 x2, RevTech 7.5
Radio: Spektrum DX3R, DX3S
Cars For Sale: FG 08-530 EVO w/ Sport Brakes!
Track(s): http://www.rctrack.com
HarryN is offline   Reply With Quote
Old 08-13-2009, 03:28 PM   #8
Low_E's Avatar
Send a message via MSN to Low_E
sorry for going off-topic, but what are the differrences between Version 199 and 200? Is there such a big difference that a new thread is needed?
(I have been away for some time)
thou shall think twice or trice before hitting thee SEND-button
Low_E is offline   Reply With Quote
Old 08-13-2009, 05:00 PM   #9
Skitee's Avatar
Ii think the guys just thought that all of these setups would clog the RS INFO/TECH thread up, so they did thi solely for the "TURBO" setups.
Xray T4 2018 ~ HobbyWing Xerun XR10 Pro ~ Motiv RC 4.5
Xray X12 2018 ~ ORCA Vritra VX3 1S ~ Speedzone 4.5
POWERED BY SPEEDZONE USA
Skitee is offline   Reply With Quote
Old 08-13-2009, 05:40 PM   #10
John Tag's Avatar
Trader Rating: 42 (100%+)
Traction (h/m/l) Med/high
Size (s/m/l) Med-100x50
Class 17.5 Touring Rubber
Chassis - Losi Type-R
ESC Tekin RS
Motor - Express DUO
Motor timing -Low
Gearing 4.30
Battery 5000-40C
Firmware -200
Drag brake -65
Brake -100
Limiter -off
Neutral -10
Volt cut off -off
Motor type -bl-fw
Throttle profile -3
Sensored/dual -sensored
Push control -off
Timing boost -30
Turbo boost -10
Turbo delay -.05
www.express-motorsports.net for all your motor needs
Multi time National Champions,Reedy Champs,Vegas Champs,Birds, Champs,[email protected]
Team Associated-Express Motorsports-Trinity-Reflex Racing-A Main Hobbies-ProtekRC
John Tag is offline   Reply With Quote
Old 08-13-2009, 05:55 PM   #11
Default tekin 200
where can i get this version. can someone send it to me?
markny is offline   Reply With Quote
Old 08-13-2009, 06:29 PM   #12
Trader Rating: 21 (100%+)
Email Randy at: [email protected]
Rick "Blue" Sieboldt - Mooresville, NC
* Associated T5M * Tekin * TQ Wire *
www.tqracing.com/rc_products.htm For all your wire needs
lidebt2 is offline   Reply With Quote
Old 08-13-2009, 06:36 PM   #13
cyanyde's Avatar
This thread is solely for setup. All else please go to http://www.rctech.net/forum/electric...-sensored.html
cyanyde is offline   Reply With Quote
Old 08-13-2009, 09:59 PM   #14
Anybody got a setup for 12th scale 4cell with 13.5 on small track 60' x 60' or similiar
RoyU is online now   Reply With Quote
Old 08-13-2009, 10:32 PM   #15
Trader Rating: 20 (100%+)
Great Thread!
Has anyone got more 17.5 setups? I just want to compare different settings and FDR everyone is using. Any tekin team drivers who have been testing this new software for a while now?
bee200sx is offline   Reply With Quote
