KO PROPO EX-10 Helios q's
#781
Originally posted by Hebiki
make sure you turn up your steering travel all the way up... then adjust accordingly if its binding the servo.
thanks.anymore??i have printed the manual,and it seems hard to understand.especially the melody part,but now i understand that part.anymore of what i should look out for?
#782
i hear that the spektrum is out. has anyone put one in the helios yet? can you run in the Advanced high response mode.
#784
i am actuall interested in weather the advance high response mode will work. I understand the technology allows for it, but will it work in the helios. I know the module will
#786
Originally posted by HarshGuy
Good question ...does anyone know? ..and also how much bigger is the recvr than the one that comes with the Helios?
Now about the AVR (i think that is the acronim) I believe that the spectrum will allow it. Not possative as all the testers I have seen all have the M8. Guess I will find out first hand when my preorder get here.
Take Care All & GOD Bless,
Stephen <><
#787
hey guys.i have one question.how do u operate the lap timer?i just bought the helios yesterday,and learning all the features.i assigned the BT1 button for the lap timer.but i dont know how to operate it.please help!!! thanks
#788
press enter
hold + and - together when you see the screen...00.00.00s
it says ready (flashs)
when you pull the trigger, it starts'
now use the BT1 to count each lap
Done
#789
Originally posted by Pro4
Scroll through the menu til you get to 'lap timer'.
press enter
Done
press enter
Done
thanks man.cant wait to get my helios to the track.YEEEHAAA
#790
how to stop it???
#792
So hard to control with my Helios
My Helios is extremely so sensitive on throttle. I just tap throttle a little, my car run like at full throttle. Which make my car so hard to drive. None of my locals could think of anything what's wrong. I tried my friend's Futaba 3Pk on my car (everything same as I run with Helios), his is smooth and easy to drive with. Anybody know what's the problem?
#793
Re: So hard to control with my Helios
1. Have you set - up your ESC with the Helios?
2.Check your settings for throttle on your controller The helios has a lot of settings for throttle control!!!
3. Re-read the instructions! (i did) bec. first time out I did not read the manual carefully and was not maximixing its many features.
Good Luck
#794
Never mind, I fixed the problem. Adjust VR TH.
#795
i got my helios about a month ago and im loving it! my friend told me that there is a function for throttle preset so it will stay are a certain speed without touching anything. does anyopne know how to work this?
thanks
marshalv.
thanks
marshalv.
