Corally RDX Phi 09
#646
Hi is there any setups for the phi 09 US carpet spec "lipo"
I race on a medium/high grip carpet using rubber tyres
Also any mods hop ups etc i should do to the car, Any weak points ect.
Also im in the UK and find it hard to get all the spares is there any shops in the US that will ship to the UK.
Thanks Steve
Thanks Steve
Try http://www.modeltech.co.uk
What Mike dont know about the corally Phi 09 aint worth knowing seeing as he designed the diff for the car.
Suggest you call thursday or friday at latest though as he is away after then.
Setup try http://www.corally.co.uk/ setup section you will find http://corally.co.uk/files/phi09-230111(1).pdf which might give you a few ideas to try.
#647
If anyone is interested Spec-R TA05 gear diff drops right in in the back if you invert the std bearing holders. But you must use 37t pulley in front and different belts depending on which pulleys youīre using. But itīs doable.
With 37t gear diff with std 36t pulley in front and 21t pulleys you have to use std 507 mm front belt and Xray (or similar) 189 mm rear belt. You will get some overdrive if you use 36t pulley in front instead of 37t...
#648
Thanks for the tips guys. Will be giving Modeltech a ring thanks for the heads up. Good to see someone else running the car in the UK thought it was a bit thin on the ground.
Are you using the square weights the go in the chassis? If so how many.
Steve
Steve
#650
Steve
#651
Pics.
Using 37t TA05 Spec-R gear diffs, 21t centre pulleys. Std 507 mm front belt and Xray 189 mm rear belt. Mid-centre rear bearing holders.
#652
#653
#655
Yes but I think Corally ones also will fit without problems. Iīve run 15 packs with the geardiff now and the rear belt still looks good, this with a 4.5t.
I had some problems with the bearing holders first because the gear diff grinded down some material on the left side holder but itīs fine now. I donīt think Corally will release a gear diff so this is the best solution so far. And in modified you must run a gear diff nowadays.
#658
#660
Randy - Just put a 42 tooth spool up front and run the BD5 Gear Diff in the rear. You will end up using the same belts as I had posted earlier.
