TC3 Forum
#7382
i also suggest pre threading the screw holes for easier wrist action later.
i dont like the aluminium screws at all,well i do like the colours but they bend and strip too easily,and being in Asia,i've converted almost the whole car to metric(M3) screws.these are FAR stronger and it also offers more clamping force.
#7383
Re: new guy, from RCZ forums.
Originally posted by R3VoLuTiOn
Hi Guys! This would be post number 1 for me at these forums. Seemed like a very active tc3 thread so Ive decided to join. I bought my tc3 used, it was a old school tc3 team with no set screw adjustment for droop. It runs ok but does anyone have any tips on freeing up the drivetrain and making it smoother?(without $100 bearings) Ive also noticed that the camber links dont seem to be the same length when i set the camber equally. Would it be just my eyes?
Ive been reading the previous pages (not all ) but when you refer to 100tooth spur gears and using them with 25tooth pinions, are they 48p or 64p? What would my current 19t and 25t pinions / 72t spur 48p gear ratio convert to in 64p?
I plan to run in the stock class...I have a basic duratrax esc, with a monster stock pro and an mx-3 system. Im happy with it but I'll probably move to brushless in the future.
Any other suggestions and tips/hints appreciated. Thanks for your help guys!
How to make it smoother?well i think u should start with checking all the bearings(since u said it's a used car) there are possibililties that some bearings are shot.
u can sand the slots in the diff cases where the bearings sit.just lightly so that it doesn't clamp too hard on the bearings.
I dont know about the pitch of the gears but i dont think 48p 90T will fit the TC3.The pitch does not influence the ratio,so if u can fit whichever combo,that'll be it.
#7384
make sure your camber links are in the same holes on both the hubs (rear only) and the tower... as long as they are, and your camber is equal, the turnbuckles are the same length.
#7385
#7386
I love my tc3
Amg if your not going offroading sunday come to wynumm and take a look at my tc3 as all mods have been done.Also installed a 9x2 revolution motor and man it honks.
#7387
hey guys ,
i got my tc3 and iam hooked,,, so hook i did a traded for another one..
but i got a question ,, on the bearings with the teflon seals ,, what is the best thing to clean them with,, in my oval car i alway clean my bearing with injector cleaner and lube with zubie oil. well i know this i cant do with the seal type bearings and was woundering what i should use to clean the bearings with out taking the seals out every time.
BIGDON
BIGDON
#7388
well for weekly cleaning(or several weeks) I just use motor spray. but I have seen where that will corrode the bearings, although so far it has been ok on my car. Now, if there is a bunch of grit and @@!$ inside your bearings then you have no choice but to take the seal off to get it out.
#7390
AMG, welcome to the TC3 club
#7391
Re: TC3 front steering knuckles
Originally posted by Mark Mixon
Any suggestions for aluminum front steering knuckles. I keep stripping the associated ones, and at 9 bucks a set, figure I should be able to replace them with a lasting aluminum replacement. Any experiences? Links?
You can buy aftermarket aluminum knuckles for the TC3 and
XXX-S made by aftermarket companies like, rc-square, gpm etc
or
Change to LOSI knuckles, less stripping and will give a better steering for your TC3 plus cheaper.
WHat I did, from stock knuckles, i got aftermarket Aluminum Knuckles by SQUARE, then later shift to the LOSI Knuckles and been smiling eversince.
But I will now go for the aluminum knuckles for the XXX-S made by square or jet.
Peace and happy racing!
#7392
Re: Re: TC3 front steering knuckles
Originally posted by lem2
Here are your options.
or
or
#7393
losi steering blocks
hey guys, ...so if i want to use the losi steering blocks, what mods are needed, if any?
thanks
manny
thanks
manny
#7394
You really don't have to make adjustments other than making the tierods for the steering longer. If you don't do this, you will have excessive toe out on the front(about 3degrees on each side!).
#7395
Can somebody please post the formula for rollout.
I though you multiply the diameter times Pi, then divide by the FDR?
