TC3 Forum
#6526
Originally posted by rinkrat99
Hey BubblesTC3
Thanks for the ratio, I think i will start with between a 24 and 26 and see what happens.
Can you reccomend an easy fix for the hinge pins on all four block carriers? The set screw came loose and the hinge pin moved out towards the front of the car.
Hey BubblesTC3
#6527
Re: mod
Originally posted by tc3rookie
i race stock class currently and am looking into getting a mod motor for fun between race weekends. the objestive is speed. does anyone have any ideas on the best one reedy Kr? what gearing works well.
You could always gear up, BUT, if you do, the motor would get hotter, and hand wound mods do not like to be at full wind for too long(epoxey pops off, and winds blow, then the motor will seize).
Another thing, if your batteries are not up to the task, then you might want to stick with the stock motor. Gear up, and put a little comp fan on the motor, that way it will stay cool, yet be geared high enough to have speed, but make the batteries last for longer runs.
#6528
Bubbles.there are no marking at all.I just am frustrated now because it seems that the car has alot of steering going in almost too much and I am afraid that I am using the 2 degree block instead of the 4. 2 degree with the f-0 block in the front is not good. Is there any other way to tell?I pulled out my Hudy station and cant see how to take a reading for castor with the c-hub style carriers.Anyone ,HELP!
#6529
what exactly are you guys dremeling away inside the diff cases.
#6530
racenut - if it doesn't say anything on the carriers it's probably a 0 deg block. you can look at the block on its side and it will probably be straight up and down with no tilt towards the back.
#6532
TC4, soon??
Anybody heard anything about a TC4 coming out soon?
#6533
HeY!!!
elnitro i didn't hear anything, but they prolly won't make one anytime soon because of how well the TC3 is still doing. Prolly not until the TC3 starts having problems or other companies start making better cars then AE will prolly start designing and make a TC4, but i don't see that anytime soon really.
#6534
YAY, I got to run the Pt's I got from Reedy this past Sat. I had to mess with the gearing a bit, but ended up with: Smooth torque, good top end.
(LightSpeed Red brush springs, trinity red, and a 8.52 final ratio)
#6535
HeY!!!
=mis fitz=, did you like the Pts from reedy???
#6536
hey man, just call me mike, cause mikes the name, lol, anyways, I thought that the low-end of the spectrum was very smooth. I got rid of those copper-springs and put some of the reds on it, made it more consistent troughtout the race. My Kr's still wind higher on the straight, but I dont think that i have the gearing down for the Pt's yet. I was also messing with the timing on them and got that pretty close. One thing I do know is that I went flying by a guy in one of our qualifiers running a Kr, but I had some, lets just say heat problems. I do think that they will be alright in TC3's but at least for our track(115x65), my Kr's will probably stay on top, but I wouldnt mind proving myself wrong.
#6537
#6538
#6539
Re: TC4, soon??
Many people are/were tired of the TC3, because of how old, and simple the design was. While the design is still simple, it is probabally the best design out there. Being very easy to work on, and with the ease of setup, there seems to be no need for a TC4...
YET
#6540
well, i dont want to get into this again, but seriously, what could they change...add an upper deck, pfftt...I think they will be sticking with the current car.
