Tamiya F104 Pro!
#166
Hey einix,
Thanks for the reply!
So am I correct to say that putting the old F103 motor mount to the F104 is safe and of the same setup?
Those spacers will act as fine-tuning parts to get it to speed, so it's not so important to me. I run at stock setup for my F103.
I'm waiting for my F104 to come. It's agonising to be waiting for so long.
Thanks again in advance!
Alfie
Alfie
You may ignore the height difference if using standard setting.The F103 motor mount have a shorter post but it has a 3mm spacer under the friction plate. so the actual height are same as the F104 motor mount.
If you really wanna reduce the height of the friction plate to fine tune the car, there is still a solution. You may use the F103 C1 and using the F104 C2,C3 and C4 to build the motor mount
#167
I think it's more like your tire setup that you aren't used to.
Regarding the high speed twitchiness, it could be your caster on the steering knuckles. Hope they can come with the hopups on kunckles too. By the way, are the knuckles the same as the F103's?
I run my F103 at my local track, with a similar F103R setup. It handles like it was on rubber tires, but with tons of speed that I am never afraid of giving it the hard cornering and accelerating. It never spins out, except for hard braking in attempt to avoid some collisions. That is all.
The F104 being longer than the F103, it should handle real smooth on the straight. It's funny how it is the opposite. IMHO, it should be the tires.
Alfie
Alfie
Sorry, i was busy to prepare for the TCS race last weekend, so didn't update here.
I did run the F104 on 1 of the qualify and here is the result (while it is an outdoor track, traction are different from time to time, so i will post the 2nd place driver who run F103R on all Qualify and main as a reference)
me:
Q1 27/5:01 -F103R
Q2 27/5:07 -F104Pro
Q3 29/5:07 -F103R TQ
main 29/5:02 -F103R A-Main 1st
reference:
Q1 28/5:08
Q2 28/5:03
Q3 28/5:00
main 29/5:09 A-Main 2nd
So i assume if I ran the F103R on the second Qualify, the result should be around 28/5:00 to 28/5:06, so currently F104 still a lap slower than the F103R on my hand and still need some work on setup.
I had talk to another driver who also drove a F104Pro
we both agreed on the following
- F104 are more stable at the in-field and easier to pass thru the traffic at the in-field. The reason is the rear is always stick to the ground, it won't spin out even you have a big movement on the steering or change the direction suddently.
- On the stright, it is a different story, it is too sensitive to our steering input, and the full throttle point before the stright are later than the F103R.
- And a funny thing we found on the F104 is, you can brake anywhere you want (an exteme example is full brake, full steering at the end of stright, the car won't spin out like F103)
And both of us think we could have a faster lap if we can true our tires, the F104 tire and wheel is sold out, so we can't try this yet.
i don't have much time to spend on the F104 last weekend, i guess if I put a harder spring at the front, I may able to get a faster lap too
me:
Q1 27/5:01 -F103R
Q2 27/5:07 -F104Pro
reference:
Q1 28/5:08
Q2 28/5:03
Q3 28/5:00
#169
F104 Pro or F103 Anniversary
I am getting out of TC and want to get into F1 exclusively. Appears to be a lot more fun, and not as intense. My question is, would it be better to start with the F103 anniversary or jump right into the F104 Pro? Reading some of the posts here lead me to believe that the F104 could have problems in the beginning and may be a little hard to control until hopups are available. My driving skill is a little rusty and will be returning at a Novice/Intermediate level. With a little track time I will be able to run Intermediate level with confidence. Is the F103 Anniversary a more stable car out of the box?
#170
me:
Q1 27/5:01 -F103R
Q2 27/5:07 -F104Pro
reference:
Q1 28/5:08
Q2 28/5:03
Q3 28/5:00
me:
Q1 27/5:01 -F103R
Q2 27/5:07 -F104Pro
reference:
Q1 28/5:08
Q2 28/5:03
Q3 28/5:00
#171
#173
today release !
#174
so looks like you can place an order for this kit at towerhobbies.com as of this morning ....
any one know if a ferrari body will come out for the f104 pro kit? since this one is the mclaren
#175
What you are seeing is a lot of speculation combined with minimal running of the chassis. I think the 104 is going to be the chassis to have. I have a fleet of 103's that will go into retirement after the Nats, if I go to the Nats this year. Im a bit confused how a chassis can lack steering and be twitchy at the same time. I need to get with my hobby shop and get a 104 on order, being out of work at the moment isnt helping my ability to make big purchases either.
Obviously, things can be worked out, but the differences in general layout will produce a tendency toward a certain way of handling.
#176
A car that's narrower and longer with the weight centered is going to want to change directions faster, initially. That doesn't mean it will rotate hard or finish the corner well.
All speculation though, I wont know for sure till I build one and run it
#177
Ride hight CAN be adjusted .
Needs to be available with the Tamiya BL system.
Kit tires MANDITORY.
It does look very sweet ! I want one....
#178
Probably related, anyone noticed this yet?
Okay, apparently I have to post more to be allowed to put URL's in my posts. Goto TamiyaUSA, search "Formula-Tuned" to see the Formula-Tuned motor, with specs.
Tower Hobbies shows it as "coming soon". Seems odd to me; a high wind low RPM motor for a direct drive car?
#179
