The Speed Passion Thread >
Like Tree57Likes
Old 02-04-2014, 01:34 PM
  #12406
Originally Posted by Solara
No, you will have to use the program called STOCK1 for boost and turbo. Download the interface and use the included LCD to load software....
YESSsss thank you. STOCK1 v20 (4.5-21.5)
plenty of boost mod setup on Speed Passion website.
Like old SP GT 2.0, all range timing:
Boost Timing = "Hybrid Boost Power" ?
Turbo settings (1,2,3 and 4)?
1-Hybrid Boost Maximum: Maximum rpm?
2-Hybrid Boost slope Rate
3-Hybrid Boost Start rpm
4-Hybrid Boost Delay
Base starting point (setup) for 5.5T?
TyoBBS is offline
Old 02-05-2014, 07:07 PM
  #12407
Default newb question
Sorry if this has already been asked but I recently purchased the speed passion reventon pro and 6.5 turn motor combo for me durango dex410 but I can't get the motor to rotate the correct way. ie when I hit the throttle it goes backwards. Any help appreciated thx.
DR.FAST is offline
Old 02-05-2014, 09:27 PM
  #12408
Originally Posted by Manual
WARNING! When using a sensored brushless motor, the A, B, C wires of the ESC MUST
connect with the motor wire A, B, C respectively. Do not change the wire sequence!
The motor sensor cable must be a non-crossover wire.
 Connecting to a sensorless brushless motor
When using a brushless motor without a Hall Sensor, the #A, #B, #C wires of the ESC can be
connected with the motor wires in any order. If the motor runs backwards, swap any two of
the motor wire connections.
If you have sensored may be you have reverse mode in your transmitter
regards
TyoBBS is offline
  #12409
rc car guy's Avatar
is your motor wired correctly, if so go into your controller setting and reverse the throttle, i dont believe you can reverse it in the software itself
rc car guy is offline
Old 02-06-2014, 11:37 AM
  #12410
Does anyone have a suggestion for a F104 chassis. I ordered a brushless 1-2s Toro/Turnigy/Skyrc, but it's a bit large for my liking under the body.
Measuredpath is offline
Old 02-09-2014, 09:46 AM
  #12411
Just saw the V3.0 2009 model 5.5turn on the website. Priced less than $40? Is that motor still available? Seems like a SMOKING deal! Just got a new 22-4 and that wheeler seems to want a 6.5 or 5.5 turn, is the older v3.0 OK for that application?
frankenstang is offline
Old 02-09-2014, 12:53 PM
  #12412
32819toon's Avatar
Originally Posted by 32819toon
Manual says double tap but it doesn't work like that. I'll re-program the ESC & see what happens
I re-programmed the esc with my transmitter and on the stand it worked fine, also in my 1st heat, but in my second heat it let me down again by not reversing when I got tagged & put against the boards, costing me a lap on two occassions. I've bought a new esc for my son and after my problems and continually being let down by Speed Passion I've bought another brand. I've got to try to sort out my esc before this Thursday, but I just don't have the confidence with this esc.
32819toon is offline
Old 02-09-2014, 02:02 PM
  #12413
rc car guy's Avatar
Your using reverse in a race? No turn marshals?...
Old 02-09-2014, 02:31 PM
  #12414
I tested Team Power ESC by default settings for my motor and I had incredible top speed!!!
My first test with reventon PRO 1.1 - 5.5T by default 125k very slow ... A lot of seconds until finish straight and no increase top speed...
I changed my setup but slower than XPS.
DRRS: 7
Hybrid Boost Power: 50
Hybrid Boost Maximum: 150
Hybrid Boost slope Rate: 12
Hybrid Boost Start rpm: 6000
Hybrid Boost Delay: 0.4
Next weekend
DRRS 9
Power?
Slope?
More changes?
Thanks and regards
TyoBBS is offline
Old 02-09-2014, 10:19 PM
  #12415
Try to lower the hyper boost delay to 0.1S, and use the stock 1 profile.
DRRS: 7
Next weekend
DRRS 9
Power?
Slope?
More changes?
Thanks and regards
rchobbymart is offline
Old 02-09-2014, 11:28 PM
  #12416
32819toon's Avatar
Haha - good question - where are the marshals ? Seriously though, unless you crash at a marshals feet its quicker just to reverse out. If you stay still the marshal thinks the car is broken and picks it up ! That also happened to me last week.
Old 02-10-2014, 01:52 AM
  #12417
RC GB's Avatar
NEVER RACED AT RC TRACK WHERE REVERSE IS ALLOWED. I WOULD NOT RUN WHERE IT IS ALLOWED
RC GB is offline
Old 02-10-2014, 04:08 AM
  #12418
32819toon's Avatar
We're quite informal, race what you've got. Reverse is much needed, especially in the novice / kids heats.
Old 02-10-2014, 05:03 AM
  #12419
sgp-chris's Avatar
Hi,
I have a Speedpassion V3 17.5T that I bought from RCMart. I bought it for my touring car, and ever since i turn it on for the first time, it has played tricks on me.
Im not quite sure it's the motor though. I use a Hobbywing V3.1 ESC.
It has alot of play in the rotor, I can push it in about 2mm. Is that normal? My 13.5T have no play at all, and a fellow racers old V3 also has no play...
The problem is that it can run just fine for a short amount of laps, and then it starts to quit on me. It won't turn over on it's own, unless I give it a little push or turn the wheels on the car by hand.
I have tried changing the sensor wire, but that didn't help.
Any ideas?
sgp-chris is offline
Old 02-10-2014, 05:15 AM
  #12420
OK, thank you i will test it.
With my last LIPO:
Anybody with the same problem?
regards
TyoBBS is offline
