The Speed Passion Thread
#991
Speed Passion Timing shift
dfiantii
Maybe you should just get whatever it is that has time shift and leave SP out of your rig.
maybe better get teamwave Rb-50 to skip SPGT2lpf
but not with SPGT2pro, it's Higher than teamwave RB-50.
and never get that teamwave RB-30 and tekin RS, replace them with tekin RSpro , it's better.
while Still SpeedPassion had some Timing shift technology issue.
SpeedPassion is just one step behind all that.
This is all about timing shift right now, which is can be done with their firmware, without hardware changes inside Speed Passion GT2.
Other than that is turbo tech, which is another issue on Speed Passion.
that might be adopted from teamwave, but might required hardware changes.
So, SpeedPassion must release timing shift, because it's legal.
#993
I have to agree with Matt.....At one point P.E.T.A is gonna get mad about the abuse that horse is getting!!!!!
I do perfectly well at my local track with my GT2.0 against the Tekin timing shift program a freind is running.......That 10th of a second, I make up with my setup!
#994
because they don't have something what you called "timing shift"
not because it is legal, but because you keep insisting them.
#995
Well might be the name is not Timing shift
but still you do like it don't you ?
as Team Wave or Tekin users Does..
#996
Could somebody tell me what is the difference of ESC timing and motor timing with sensored motor, please?
Since you have timing in motor then the ESC timing could working in the same?
Best regards
Best regards
#997
they work's the same based on sensored position.
when the fixed motor timing is adjusted/set phisically,
the esc will add more timing depend on motor timing you set it, and how many esc timing you set.
so it's like motor timing + esc timing = total timing.
therefore some factory would recomend linear motor right now,
do to some knowledge about this. to avoid over timing.
some factory will add limited motor timing adjustment, to avoid the over timing.
hope this will help.
#998
replacement / spare female bullet connectors for V3 motors
I'm looking for a source for the female bullet connectors that are specific to the new Speed Passion V3 motors. If I ever lose one I'd hate to have to buy a whole motor just to get replacement connectors !
#999
Irgo, you seem to be always moaning about speed passion in some way or another, first it was that you wanted brushed functionality on on the gt2, now you want timing shift. Team Wave's timing shift is just shifting timing from one value to another, the gt2 already has the ability to set different timing in the esc.
#1000
Team wave does both of that, Timing set and timing shift. And other is Turbo.
SpeedPassion GT2 only had Timing set. and where is the gt2 timing shift..?.
and
note:
brushed enabled and timing shift can be done with firmware.
doesn't required hardware changes for SPGT2.
So, it's only required their firmware/software development.
and i believe SpeedPassion can do that.
the prove is what happened on GT1 (brushed mode),
the differences "brushed modes" is only the firmware/software inside ESC.
Which one you didn't get the point ?
#1001
Edit: you do realise there is hardware differences between the gt2 and gt1?, just because the gt1 had brushed, doesnt necessarily mean the gt2 can operate brushed, even with different firmware..
#1002
Which point didn't you get?, Team wave only has a timing shift setting, which is actually to set the timing. If you referring to dynamic timing, where the timing changes as rpm changes, Shawn mentioned earlier in this thread that the GT2 does something similar, but couldn't go into too much detail for obvious reasons. Most of your comments in this thread has been a bash at speed passion, you went on and on earlier demanding that speed passion implements brushed mode, now your hitting the dead horse again demanding speed passion implements "Turbo", i am sure they are working on software that will give the same aspects of "Turbo", as someone mentioned earlier, if you dont like speed passion, then choose another esc that meets your "needs"
the firmware does it all the brushed mode on GT1, the difference in gt2 is only some capability to handle the power, and i have mention about that, that's why shawn say they will fix the information about GT2lpf blue star.
and i don't asked for Turbo yet..
and i do might agree with that dynamic timing.
sadly it's AMTS Advanced Multi Timing System, why not Dynamic Multi Timing System.
So if Dynamic Multi timing is a Timing shift, we would not have to leave SpeedPassion right ?
This AMTS /Dynamic Timing is Timing shift on SpeedPassion GT2.
Shawn is this True ?
#1003
Amazing all the moaning about the GT2.0! If you don't like it, get something else!
I have experienced many of the modern ESC's and there isn't a huge difference on the track. That said some do have more potential is some areas. In general I have found the SP to be the most bulletproof speedo out there. It dosen't go up in smoke 1/2 as easy or destroy motors. That said I think it does lack a bit in the rpm department but most people out there are trading so much torque for top end that you won't have trouble keeping with them anyway.
#1005
Which point didn't you get?, Team wave only has a timing shift setting, which is actually to set the timing. If you referring to dynamic timing, where the timing changes as rpm changes, Shawn mentioned earlier in this thread that the GT2 does something similar, but couldn't go into too much detail for obvious reasons.....
where timing changes as rpm changes is not completely true.
SpeedPassionGT Does this :
what changes when rpm changes is ("Hybrid Drive")
("Hybrid Drive") switching between sensor and sensorless depend rpm.
"Therefore - any timing advance position on the motor (sensored based)
aren't used anymore".~Schumacher USA
Dynamic thing, is Timing Advance that will
take changes best/ideal advance timing level when/anytime
you're throttle position changes on transmitter.
