The Speed Passion Thread
#7636
Any news on any new ESC coming out?
#7637
Anyone got a tip about starting higher or lower on the FDR for the new MMM 10.5 motor compared to the 10.5 1Cell? Was running 7.05 on the V3 1 cell with 110323 stock, but the same settings did feel slower on the MMM.
#7639
Received my 13.5 MMM motor today... What should i be looking to gear around on a 20x14 circuit using Hobbywing xtreme.
Cheers
Cheers
#7640
1. Boosted or SPEC ESC and what firmware you are running.
2. Your current Speedpassion ESC settings
2. Your motor brand & physical timing
3. Your current FDR
4. Your track conditions: Tight or open, how long the straight is, etc..
And also dont forget that www.speedpassion.net has a section dedicated to ESC setups for all forms of racing.
Jimmy
#7642
Try 7.5 final with 15* timing on can...I have yet to run 10.5 MMM and this is just my wild guess....
#7644
I remember when we had the 1st gen of the BOOST stock software...I blew up (4) 13.5 motors within 3 hours (until I ran out of 13.5 motors, then I go to the 17.5...3 more blew up within another 2 hours)...1 motor per round, less then 3 minutes each. How many motors you can provide and how many DNF you can afford?
#7645
R/C Tech Elite Member
#7648
I was wondering if anyone has a problem with a KO PROPO 10 binding with a cirtix club esc.I used the cirtix with a M8 with no problem,changed radios and can't get it to bind.I go through the set up in the book and on SP internet and the lights do what there ssupposed to do but then the red light starts blinking.I've tried I don't know how many timesto reset both of my esc with no luck.If any body has a idea post it please.
#7649
