Old 03-06-2013, 06:36 AM   #3856
Can anyone tell me the specs on Schumacher's yellow inserts?? Like the ones used in the Sorex Pre-mount they sell.
Serpenteer is offline   Reply With Quote
Old 03-07-2013, 02:44 PM   #3857
Martin Hofer's Avatar
Send a message via ICQ to Martin Hofer
Hey guys
finally managed to update my blog again
Check it out here
Schumacher Racing
Team GM-Racing
Team Sorex
Xenon Racing
Tonisport
Martin Hofer is offline   Reply With Quote
Old 03-12-2013, 09:39 AM   #3858
Racer X's Avatar
Martin: I'm sure that it's just been an oversight, but thanks for updating and sharing all of the information. Now if you could only have a picture of the car with the body taken off...
Schumacher Mi6
Speed Passion Motors and ESCs
Integy
SpeedWorld Raceway Roseville CA.
Racer X is offline   Reply With Quote
Old 03-12-2013, 12:33 PM   #3859
roger999's Avatar
+1
r o g e r g r a f i x . c o m
facebook.com/rogergrafix
roger999 is offline   Reply With Quote
Old 03-13-2013, 08:40 AM   #3860
Hi Guys,
Does anyone here have any experience of the Team Orion R10 Pro ESC or the LRP Flow Works Team ESC with the Mi4 models?
Looking at these on my ESC shortlist for my CXL and looking for something that can work in Blinky AND mod class that is easy to configure between the two. Apparently they both can.
Any feedback appreciated on these two ESC's and/or comparisons if someone has used both.
Thanks,
Hoof
TheHoofmeister is offline   Reply With Quote
Old 03-19-2013, 07:44 PM   #3861
what better car to start or MI1 Mi4cx?
Revinho is offline   Reply With Quote
Old 03-20-2013, 01:52 AM   #3862
Pinion King's Avatar
Send a message via MSN to Pinion King
Originally Posted by zaraz View Post
so release date on the mi5 yet
Late April I have been told.
Schumacher Mi6
Schumacher Eclipse 1/12th
Pinion King is offline   Reply With Quote
Old 03-20-2013, 09:06 AM   #3863
Racer X's Avatar
Revinho: Given the choices you presented, there really isn't a car much better then the Mi4cx. The Mi5 is going to have to be incredible to get me to give up my Mi4cx.
Schumacher Mi6
Integy
Old 03-20-2013, 10:07 AM   #3864
Thank you. I'm going to buy the car at the end of the year.
Old 03-20-2013, 02:49 PM   #3865
The answer might be totally different by then. Mi4CXLs will probably be dirt cheap on the used market by then.
-Mike
Old 04-05-2013, 11:49 PM   #3866
Default Newb baseline setup
Alright gents. I have read through all the posts, built my CXL, rebuilt after re-reading some posts and now have the joy of waiting until the 20th of April for our season to start. I am hoping to get some pointers on a baseline setup including thoughts on front to rear weight distribution, springs ... etc. if you would be so kind.
Take a look at my setup, laugh, cry whatever the case may be and please let me know how it looks. I tend to like more aggressive steering. Class is 17.5 blinky and first time racing TC in way, way too many years!
Since I have no clue if our track would be considered medium or large I have included a link to an old video I found .. there is a lot of talking but some bits of racing that show the approximate size though it is a bit smaller now.
Thanks!
http://www.youtube.com/watch?v=HLqjfI7djnE
_______________________________
::AE SC10.2 | AE SC10 4x4 | Schumacher Mi4CXL | Tamiya M05::
AzFittin is offline   Reply With Quote
Old 04-07-2013, 10:52 AM   #3867
Thanks!
Hi, I have recently brought the Mi4cxl and will be building shortly, just getting all my bits together first. What have you changed from the stock kit that would be of improvement/benefit? I have some of the Schumacher titanium parts and ceramic bearings. I have read somewhere that it may be worth trying different shock pistons, o-rings etc that are not schumacher too so just wondered the route you have taken?
Old 04-07-2013, 08:13 PM   #3868
Car Breaker's Avatar
I personally recommended
U4064 C/F Long Top Deck Flex,
world mod lower suspansion block,
front double joint universal,
and a properly built SpecR gear diff for tuning.
stock top deck made the chassis too stiff for my liking, had hard time tuning the car for my local track and my driving style. I notice that after driving a T4, switched the topdeck made the car much better but I still moved on to T4 after a whole year of abusive driving. my schumacher wear out too much and cost almost a car to repair.
Xray X12 2015
ARC R10 ATS
Car Breaker is offline   Reply With Quote
Old 04-07-2013, 09:49 PM   #3869
Hoofmeister ... I have to defer to others for what the best changes are as this car is brand spankin new to me. I can let you know that I picked up a set of HPI springs #75175 and one of the SpecR gear diffs as those two items are mentioned quite often. I also replaced the stock turnbuckle ends with a set of Associated ones (31305) as I could not get them to loosen up at all. Tried the whole squeeze with pliers thing and could not get it to work for me.
On the pistons and o-rings I will wait and see how it performs before making any decisions. I also stuck with the stock bearings for now. I figure when one fails I will get a set of the ceramics but until then I will use the time to learn how to drive the thing.
I am looking at Lipo retainers but am toying with the idea of running a shorty instead of a full size battery so for now will just stick with the stock setup.
Not sure if any of that helps but it is all I got.
Old 04-08-2013, 12:47 PM   #3870
Dusttt's Avatar
Trader Rating: 118 (100%+)
I am building a cxl as we speak and my problem is that to get the arms to move freely I have to back the screws that go though the pivot blocks and into the hinge pins way off. Anyone have a tip here? Or should I just thread lock them in loose?
Also the lipo holder thing is not impressive anyone got their own setup for this?
"Whiskey Tango Foxtrot"
Dusttt is offline   Reply With Quote
Hot Bodies Cyclone Frank McKinney Electric On-Road 19761 10-14-2016 03:50 AM
Schumacher Corner meche Electric On-Road 27727 07-20-2015 07:38 PM
2009 SEQ Onroad Interclub LOSI123 Australian Racing 348 01-06-2010 10:08 AM
Racecraft TC Challange 2 Kylelim Singapore R/C Racers 82 08-01-2009 12:07 AM
Schumacher Mi3/3.5 parts and roller!!! Eastcoast13.5 R/C Items: For Sale/Trade 21 07-19-2009 01:15 PM
Opinions on TC's hippie Electric On-Road 58 07-08-2009 10:14 PM
