Over steer problems
Over steer problems
I run a TT-01, using it to drift.
It's current bone stock right now. But i run lock diffs front and back.
And the tt-01 oversteers alot! How do i fix this?
Thanks in advance.
Edit: I found out the front diffs got unlocked somehow. But the problem is still here, So do i need them semi locked?
Thanks in advance.
oversteering is good for driftinf though.. make sure your rear tires aren't too worn in comparison with your front
Suspended
With diffs already locked.
Oversteer problem = loosen rear diff
Understeer problem = loosen front diff
