Old 03-10-2009, 03:27 PM   #1
Unhappy Over steer problems
I run a TT-01, using it to drift.
It's current bone stock right now. But i run lock diffs front and back.
And the tt-01 oversteers alot! How do i fix this?
Thanks in advance.
Edit: I found out the front diffs got unlocked somehow. But the problem is still here, So do i need them semi locked?
grategenin is offline   Reply With Quote
Old 03-10-2009, 03:40 PM   #2
Thumbs up
Thanks in advance.
oversteering is good for driftinf though.. make sure your rear tires aren't too worn in comparison with your front
bingo222 is offline   Reply With Quote
Old 03-10-2009, 03:41 PM   #3
Phat-Boy's Avatar
Trader Rating: 25 (96%+)
Default tt-01
try unlock front diff. you only need lock rear diff. what kind motor and tires are you using? it is hard to drift with fast mod motors and abs pipe tires have no control.
Phat-Boy is offline   Reply With Quote
Old 03-10-2009, 04:45 PM   #4
Suspended
With diffs already locked.
Oversteer problem = loosen rear diff
Understeer problem = loosen front diff
Lightin' is offline   Reply With Quote
Old 03-10-2009, 04:48 PM   #5
100% sure?
Because phat boy says to unlock the front diffs....
Old 03-10-2009, 07:52 PM   #6
kschu's Avatar
Trader Rating: 16 (100%+)
Send a message via MSN to kschu
u can try use softer spring at rear to give ur rear alil more bite than front...
Give the best while u can !
kschu is offline   Reply With Quote
Old 03-10-2009, 08:25 PM   #7
For drift you want stiffer springs at the back.
And i loosened up the front diffs. Worked like a charm phat!
Hpi Pro 4 Barry White Electric On-Road 16065 12-13-2017 07:32 PM
kyosho electric offroad b-man777 Electric Off-Road 9014 12-22-2012 08:36 AM
Ask Steve "The Evicerator" Weiss TeamButter Electric On-Road 7088 07-16-2011 06:01 PM
MBX5 is here!!!! TambokGT Electric Off-Road 566 01-30-2009 05:30 PM
racermac71 Help!!!!! xlgraphicspro Buyer/Seller dispute and Feedback discussion forum 23 04-19-2006 08:22 PM
Trinity G4 - Team Magic G4 E-Type puma1824 Nitro On-Road 3128 10-04-2005 05:17 AM
