New Yokomo TC, the BD-5
#2868
thanks to everybody for the warm welcome words!
the setup I posted yesterday based on the WR/WX chassis.
#2869
Hi-traction or WR chassis
Hi, Ronald.
Which do you use hi-traction or BD5W(normal) chassis?
I think Indoor carpet tracks are almost high grip and hi-traction chassis is too much roles. How do you cope with that situation?
#2871
Andrea
#2873
I did 2 races this indoor season with the WR chassis and worked well too, but traction wasnt that high there.
I think if traction increase (races like ETS, LRP TCM etc. has always high grip due toa 3 days event with many entries), I would recommend WS chassis.
It feels easier to drive with a bit more understeering than WR, but its not that WR never works on carpet... opposite on asphalt, if WR chassis works well does not mean WS is half a second off...
#2874
I just make sure the car is straight after building checking this on a flat setup board,glass board or 2 flat blocks. After I finished I check left/right balance by lifting the car below the rear and front shock tower on the same time to see if it falls more into one side and then I put weights into the car were needed or move the electronics a bit. Normally I put also weight into the bumper (10-20g), car is feeling more smooth.
I think you discussed this here before with the HUDY tool? couple of pages before...
and in case I crash I also check if the car is still straight,sometimes nothing is bend but not straight because some aluminium parts just moved a bit without beeing bent...
#2875
Ronald, do you usually use the 8mm steering center link? Also I ask this on last page regarding zero rebound shock, do you drill a hole on the top shock shaft to get zero rebound. I always see your car is using the longer rear stabilizer, what difference does it make compare to the stock one?
Thanks.
Thanks.
#2876
hi ronald what gear diff oil do you use?
#2878
Thanks.
Thanks.
(from Team Yokomo)
#2879
I'll try WS chassis on high grip track.
#2880
Ronalds Setup
Hi Ronald,
Great to have you on board. Maybe I can you assist you a little.
