Tamiya TRF415
Originally Posted by Xanavi_R34
hello.
Ei, what do you mean by "it doesn't have the punch at pull away like the higher end ESCs but once at speed it's fine." Right they say it can destroy the stock esc if you use the tz or rz motor?
The ESC that comes with the TT01 is rated for up to 23T motors. Obviously depending on the 23T motor timing it might pull too much amps and the ESC will eventually die, but it most definately works fine with the Tamiya TZ motor (which is what I used)
Ok bit more back on track. Having got the MSX going how i like it (finally) i was wondering what a wider front track width would do to the handling of the car, i was thinking more mid to exit steering? Also what would having the front wishbones pointing straight (say with a A-A block) feel to a car with wishbones pointing \ / (with B block on front then A on the rear)?
Cheers, Charles
Cheers, Charles
Charles,
Making the front wider will give you less steering and more stabillity!!
If you need more mid/exit steering you should really try some antidive up front. Today I tested with 0, 0.5mm and 0.3mm under the A-Bridge. I really liked the 0.3mm the best and that also gave me the fastest laptimes!!
With 0.5mm it was a litle too much on power steering, but 0.3mm was perfect!!
Running the A-A blocks would most likely give you a litle more steering all around.... very easy to test, two screws, voila
Originally Posted by Eirik
Charles,
Charles,
Having the front suspension block higher than the rear gives kick-up. Having the rear higher than the front gives anti-dive
A wider front track reduces steering.
oh, I see... So allan colico teaches you how to drive an rc car for 1k? that's cool... Ei, bro, can you teach me how to get to pasig race track? the one rc drivers are talking about when sometimes the race is not at the ps1. Dunno how to get there eh... raymond, and his friends are telling me to visit there sometimes but I really don't know how to get there... I bought my tt01 kasi late na eh.. The tt01r came just last week ata. sa lils, 2 lang ang nakikita ko pa lang... I wanted to buy that though but never mind... hehe...
it's okay... c5, diba iba sa the fort, ung speedzone? or yun un? Text me na lang sa phone ko - 09164361149... I need a charger with discharger and batts... Where do you think I get get those for less costs? do you know anyone?
dude, forgot to tell you na the number that you were trying to calling awhile ago is with my grilfriend.. Sorry.. Anyway, do you race or run your rc's at the parksquare1 roof top parking lot? if youwant, we can meet personally.. Thanks for the info about the chargers and the batts...
Cheers, i'll give it a go
Charles
Charles
1) coming forom Mega Mall (take julia vargas) go to the direction opposite edsa, going down to c5.
2) when you get to c5 (shell at your left), turn right
3) go to the most left lane since you'll be making a u-turn at the first u-turn slot you'll see (about 200 meters away from the corner of julia vargas and c5).
4) once you make the u-turn go straight
5) don't go over the fly over, go under
6) Tiendesitas should be at your left
7) it's the blue gate at your right (the blue gate is near the u-turn slot under the c5 flyover
8) beep beep ka lang, may security guard doon
9) i'll text you pagmaglalaro ako doon pagbalik ko ng marikina
10) bad trip nga eh, walang rc track yung pupuntahan ko
hope this helps, kung mawala ka man bro, text ka lang!
Sorex Tires versus TakeOff
Hi all,
I am having one important race in a big track with medium to low grip .
Air Temperature will be 21°C or 81°F.
Since any rubber tire/insert/rim combination is allowed and no limit for the number of tires used - is a total new situation for me , used to run TakeOff C27 limited to 2 sets per race (mandatory tire).
I will be thankfull for any advice base on experience about how to get the best of this conditions, like which tire/insert can be the best
and
If is wise to use one tire set for each run (4 qualifying and 3 finals).
thanks in advance
Cy
and
thanks in advance
Cy
I would suggest you try Sorex 36R, Orion Hard Wheels and Orion Yellow Asphalt inserts. Additive = Tire Tweak with Tire Warmers for 30min. (55deg C.)
The Hara Grey Ver.1 inserts also works really good!!
The wheels are very important as different brands have slightly different size!!
New tires are always faster, especially when it's hot!!
