Tamiya TRF415
#5356
Re: droop settings!
Originally posted by maxepower
The larger the number on the Yokomo gauge the less the droop!
Right?
Right?
BTW as an aside, when setting droop (and the car in general for that matter) I always do it the same way, by checking the ride heights first (setting using shock collars), then droop, then any other adjustments (camber toe etc). It just makes sure that I always set up the car the same.
HiH
Ed
#5357
Originally posted by razzo
Nice box on 415MS.. Poor Mazumi though, get a car named after him, only to have someone else's picture/car be featured on the box.
#5359
Re: Re: Champ Hobbies
Originally posted by Randy Caster
They are a vendor on this board, check out their forum section. I try to support the people that support the site.
Here ya go Click Here
#5363
koabich,
thanks for your help
J-P
J-P
#5365
What shock setup are you guys using with the LW suspension arms? I have the stock shocks, 2 hole pistons (didnt include 3 hole) and 40wt oil, and it feels like it's waaay too stiff, does that actually work on this car?
Originally I went with 2 hole pistons and 50wt oil, and thta feels pretty similar.
I'm not sure thats what you want to hear though....
HiH
Ed
#5366
Just wondering will tamiya still make the MS edition or will it be one pre order like the yokomo and that's it
Chazz
Chazz
#5367
I had been running 40 wt oil in the front and 3 hole pistons and 30 or 35wt oil in the rear with 3 hole pistons. Rick
#5368
Originally posted by TryHard
I've been running 3 hole pistons with 60wt oil recently. But I think I might drop down to 50, and generate a little more grip.
HiH
Ed
HiH
Ed
#5369
Chazz
Chazz
Race success = new chassis
#5370
Originally posted by RC Driver Gary
Very funny. Only 1/2 a Mayo jar, eh? I actually need the numbers and sizes to help someone out.
5mm x 9mm 8 each
5mm x 8mm 2 each
10mm x 15mm 4each
4mm x 8mm 2 each
for the regualr 415
5mm x 11mm 8 each
5mm x 8mm 2 each
10mm x 15mm 4each
4mm x 8mm 2 each
