540 Gear Ratio
Changing the spur to a bigger one will make your ratio go from ie 6.5 to 8.5 if you go up in the number of teeth. Increasing the pinion number of teeth does the opposite. For ratios for Silver can racing, try a 90 tooth spur with a 50 tooth pinion for the cyclone s, which is around 4.4 It really depends on the track.
