Old 01-20-2009, 11:50 PM   #1
Default do lower turns motors give less less braking
Hi there
do lower turns motors give less less braking ??
1101 is offline   Reply With Quote
Old 01-21-2009, 03:03 AM   #2
tc3team's Avatar
I don't know for a fact if they have less braking or not, but in a logical sense, if you are travelling faster, you ideally need more brake FETs and/or a stronger brake frequency to get the car to slow down or stop quicker.
This is why a lot of budget, low end ESC's cannot handle a modified motor, as the FETs are usually of a cheaper,inferior quality.
I don't understand motors enough to see why there would be less braking in a modified motor, with less windings for current to pass through, I would have thought they have more braking, as there is less distance for the current flow to negotiate.
But, logic never answers everything...
Fusion Hobbies / www.horshamrc.org
The wife stops me being sane and the r/c stops me from going insane....
tc3team is offline   Reply With Quote
Old 01-21-2009, 03:22 AM   #3
sosidge's Avatar
The only motors I've noticed with significantly less braking are silver can 540s, mainly because they have such a weak magnetic field, and low brush friction.
All my race-spec motors have good braking, never been a problem slowing down on the track. Although personally I rarely use the brakes anyway!
Old 01-21-2009, 09:27 AM   #4
mok
mok's Avatar
Send a message via MSN to mok Send a message via Skype™ to mok
to me its related to gear ratio and torque...
lots of starting torque pretty much equates to lots of stopping torque
lower FDRs brake less than higher FDRs (for the same motor)
it seems to hold true for my experiences at least, but i am sure someone else can explain it correctly and with more explanation
XRAY T3'2011 / TEKIN RS PRO / LRP X12 / HYPERION SWIFT G3 RACE PACKS / FUTABA S9551 / SPEKTRUM DX3R
www.epracer.com - www.precc.org.au - www.westcoastmodelrallyclub.asn.au - www.onroadrccarclubbunbury.org.au
mok is offline   Reply With Quote
Old 01-21-2009, 03:01 PM   #5
From experience the more powerful the motor, the stronger the brakes. Any spec motor I run needs the brakes dialed up to almost max to get the car to stop but mods you only need around 60% to stop quick.
Blade: Andro Treiber H 79g AN
FH: Donic Bluefire M3 Max Blk
BH: Donic Bluefire M2 Max Red
Powered by Falco
Dragonfire is offline   Reply With Quote
Old 01-22-2009, 12:55 AM   #6
Default motors
I don't know the answer either but my thoughts:
Assuming magnets and armatures are the same in the two motors
Less turns would have more braking cos less wire on armature = less resistance.
A motor that has more turns as we all know goes slower because it has more windings(wire) = more resistance so it needs more power to slow down.
yeahyeah is offline   Reply With Quote
Old 01-22-2009, 01:19 AM   #7
+1
CPD Racing
chris_dono is offline   Reply With Quote
Old 01-22-2009, 02:22 AM   #8
tc3team's Avatar
Yes, I was thinking something like this, just wasnt too sure of the technical side to it... This is something I need to learn more about
Old 01-22-2009, 04:30 AM   #9
You will find its not just the brake power, but the way the brakes are delivered. Novak motors for instance tend to have very weak brakes until you dial them up to max. LRP motors have crazy braking at high speed but the brakes disappear as you slow down. SP/Orion tend to be a little soft up high but very linear mid to low.
You really need to try you motor out and adjust your settings to suit you driving lines.
Powered by Falco
Old 01-22-2009, 05:03 AM   #10
tc3team's Avatar
I mostly race in stock (27t) and have done primarily for quite some time, so I usually need little brakes in general, but thanks for the heads up
Sometimes I will put a 19t in and usually change the brake frequency, as with gearing I usually find that I am mostly with the right choice, and dont want to loose too much speed down the straight by gearing with a smaller pinion.
So much to learn, 15 years and still learning lots!...
Old 01-22-2009, 08:39 AM   #11
on track, lower-turns motor will break better, because they can create more power. But if the gear ratio in a car is the same (5.5 an 13.5t for example), the 13.5 will break better (because of more torque)
But that all doesnt matter. Most ESC can adjust brake from verly low to extrem high. It just depends on your ESC setup.
Der Dicke is offline   Reply With Quote
Old 01-22-2009, 10:11 AM   #12
joe of loath's Avatar
I think the term for stock racing is 'brakes? what are they?'
HPI E-Firestorm - Tamiya TA05 racer (carbon chassis, 10.5 brushless etc) - LRP Blast S10 BX - Revo 2.5r truggy conversion (in progress)
joe of loath is offline   Reply With Quote
