008 US rubber tire setup
Hey All,
Just wondering if anyone has a good base setup for a 008 foam spec with rubber tires on carpet. It is for my fiance and I want to make the car drivable for her.
Thanks,
Kane
Thanks,
Kane
A good starting point is the one in the manual and you can always go to the xray forum and find setup sheets.
Super Moderator
I posted here as all the set-up sheets are now 008/009 making it more difficult to find the 008 rubber tire set-ups.
Thanks,
Kane
Thanks,
Kane
Well you not going to find a setup sheet for you car since you have a 008 us foam edition with rubber tires so look for a 008 eu rubber edition setup sheet.
I have both a 008 and 009 EU spec so no shortage of set-up sheets.
Allow me to clarify my question:
Is there anyone running a US edition 008 with rubber tires on carpet? If so, what changes did you make to fit this scenario?
Thanks,
Kane
Thanks,
Kane
008 foam/rubber setup
Kane-o contact adamage he was running a very good rubber setup with a foam 008 car. You might be able to find it on xray site as he posts them there quite often. If not he can probably get you the setup info.
Thank you sir, axtually come to think of it I did ask Adam that question at the start of the season. i guess i should check my messages
