Warpspeed Demon and Demon 2
#1951
Originally posted by TC3er
I would go with the IRS one, or you can just take a regular diff and take out the balls and tighten the screw all the way down.
#1952
Thanks guys...
Has anyone seen the AE for the Electic?
#1954
Originally posted by wolfeman09
Thanks guys...
Thanks guys...
#1955
GOT REEDY?????????????
#1956
Originally posted by howard hudson
yes I have seen and bought it
I called AE and here is the deal, 1703 is for Electric and 1704 is for Nitro and there is a difference. 1703 is shorter on the outdrives and will keep the car at 190mm, 1704 is longer on the outdrives and is for Nitro at 200mm.
Late....
#1957
To bad you bought the wrong one :P
Late....
Late....
#1959
Re: D2 BODY
Originally posted by BMXJEFF
WHAT BODY DO YOU RUN ON A D2 CHASSIS. DOES ANYONE HAVE PICS OF A MOUNTED BODY ON A D2 I WOULD LIKE TO SEE.
THANKS BUTCH REGALIA
#1960
bmx i dont have pics but i run the alfa from protoform and have run the stratus body.
here are a couple pointers to mounting the body correctlly! for handling not looks!
set the body on the car. (dont make holes yet!)
align the front wheels within the marked fender cutouts. then move the body forward about 1/8" th or 1/4 " of inch and mark your holes and draw your wheel openings. mark out the rear aswell dont worry about the moulded in lines .
once you have it mounted mount the wing about 1/2 " further forward then you normally would.
the reason for this is since the car is shorter and you mount the body with the front wheel cut out where marked on the body, it will act as a long tail body and create a aero dynamic push.
thous moving the body and wing forwared will eliminate a large rear over hang! hope this helps if you have any other questions feel free to ask.
#1961
Re: D2 BODY
Stratus body mounted on a D2
#1964
Its a unique Paint job, One of a Kind too
#1965
Ariel if you have a problem taping the fan on its edge. Either get some 2 sided tape without the foam. Or use shoe goo.
