Tekin RS ESC sensored
#526
Thanks TexRacer.
I have the LRP TC Sphere. It's a good esc but i don't like the sise and the weight.
I want the RS pro and i want 2 of them
#527
Does anyone where i can get a RS PRo from.i cant find stock anywhere?
#528
I've sent a PM 10 days ago to Marcos, He hasn't replied. Maybe you have better luck!!
#532
Super Moderator
no problem what ratio were you running? what timing? Ive been running 10% timing( about3 degrees) with the 3.5 geared ar 9.56fdr and its been very good the motor comes off the track around 155 and the esc around 170 (with 6 lights showing) .Im going to dring the timing down all the way this weekend and try it out see if the esc temps go down some. I added the Seedpassion power cap to it and I have a small fan blowing the solder tabs to help out. no thermal issues . Im going to try the SP2.5 this weekend , I was wondering if anyone tried a 2.5 yet
#534
I guess you're running lipo or 6-cells?
#536
Shop Owner
setup was: 5-cell, Vortex 3.0T (default timing), fdr 9.3 (very large track), 20 percent timing. Besides the TSDs i had serious trouble keeping up on the straight with the LRPs, thats why i tried to increase timing. ESC thermaled at about 230F. For the next weekend I have (hopefully some things to try out, I modified the case to let air flow through the stacked pcbs and will mount a 30x30mm fan that blows at the soldering posts through the case, I also will try a larger cap (have two tekin caps mounted at the moment). We will see :-)
#537
Super Moderator
#538
with a 3.0T Vortex?? I'd say with a LRP and a 14mm Rotor this FDR would be OK, but the Vortex has a 12,25mm rotor, thus higher RPM. BUt anyways, I have to play around more with gearing and timing
#539
Ran my RS Pro for the first time yesterday and got my best fast lap ever, down by .2. The other thing ... I almost got dq'ed for weight!! I didn't realize just how much lighter the RS Pro is than the GTB, i had to put 48grams on my car after just swapping speed controllers and leaving everything else the same.
Couple that w/ the hotwire and i'm a fan
