Tekin RS ESC sensored
Thanks for the tips guys. I will figure out some way to make my setup fool proof in the future. But for $200 plus electronics, the ESC manufactures really do need to figure out a polarity protection scheme. Instead of leaving it to the paying customer. I feel the don't make a mistake even once excuse is just neglect on their part.
I'm hoping Tekin is willing to step up to the plate on this issue, especially since most high end batteries are using bullet connectors.
This is just one of those life lessons
Doubt it will happen to you again
Most Performance ESC mfg's would not want to add weight, and, or drop the spec of their product to prevent end user errors
That's what the cheaper RTR stuff is for
I'm sure with the advances in technology, one day we may be lucky enough to have two different size bullet holes on batteries. But I feel that type of advanced technology is still far away.
/sarcasm
But jokes aside, I feel that some times RC takes a step back in technology. I see separate bullet connectors as such. It would be great to have a female EC5 or female deans connector built right into a hard case battery instead of just separate bullets. EC5 is basically notched bullets.
End Rant.
/sarcasm
End Rant.
If you recall from a previous post I burned up my RS Pro with reverse polarity. Just for fun I took it apart, I believe I can spot at least two FETs on the bottom board that are burned up. Looks like reverse polarity leads to a short from what I am seeing.
Other then that it seems there are three boards in the RS Pro. Top is the controller and firmware, the bottom two boards seem to be almost the same. They only seem to hold the FETS stacked on top of each other.
Now I know sometimes we get a little carried away but come on Son, is putting a deans connector between the batt & esc is too much trouble?? to save a $200 esc??
Just Sayin LOL!
Dude!! CloseYetFar connected his battery reversed polarity, by not for Deans. But the bullet connector plugged ito the lipo battery pack he uses.
In the "old days" we used to put a 30 amp auto fuse on the positive battery lead of the esc. It protected the esc from burning itself out. I don't know if that precaution would still be of use anymore.
He wouldn't of had a problem. And usually all it takes (for most of us) is once before you learn. Just sayin
Dad always said experience is the best teacher.
Yeah!! lipo's with bullet connector onto Deans. Lipo's manufacture could have different sizes on bullet connectors, they have smaller balancing bullet connectors. Your Vehicle the cables between positive and negative is different gauges, neg the larger. The first lipo with bullet connectors I've purchased made permanent form them so I dont make that error. Me with Tekins RS!!! Lookin' out for myself.
This might be a silly question but is the RS esc ok for TC 17.5 blinky? On the Tekin website it says the RS for 2wd only. I have one kicking around and would like to use it till I pick up a RS Pro.
Cool. Thanks for the info.
I dunno, I prefer bullets. I learned to make one lead short enough so it physically cannot reach the other battery terminal. Has been pretty darn foolproof to this point.
