Tekin RS ESC sensored
[/QUOTE]Originally Posted by Suteki
Noticing some thing odd with my car lately.
Using a 17.5 turn redline with tekin rs pro, running stock spec mode. It's fine under full acceleration but sometimes when the vehicle is stopped and I slowly pull the trigger, something is emitting a high pitch squeal and the car isn't moving, or it might move but it stutters quite a bit. Sensor cable appears to be plugged in fully.
Have tried moving the wheels and it doesn't appear anything is binding, the only time it feels like there is any resistence is turning the wheels when the motor is on the car you can sort of feel where the magnets are on turning the motor. Otherwise, no binding. Running 72spur, 36pinion with fan on the motor the ESC is never getting over 3 lights (around 110f) and the esc is coming off around 150f after 6 min of back and forth running (haven't had a chance to check temps after 5 or 6 min heats).
Everything seems fine except that little problem at low throttle from a stand point.[/QUOTE]
Randy, how do you increase the min throttle setting? Do you do this on your radio?
Increase your min throttle setting until this goes away. The esc is sensing the rotor not moving and can get to a near "locked rotor" sense. This is due to the tall gearing, belt "bind" and weight of the car. We're asking the motor to get past a lot of "stiction" to get the car rolling. Essentially the esc's min drive isn't enough to overcome this.
Most 17.5 blinky guys on the team are Min throttle between 15 and 20 depending on motor and gearing.
Thanks[/QUOTE]
With the hotwire. but you could change your expo i guess, but that kinda unconventional.
Thanks[/QUOTE]
I think the tekin part number is TT2283.
Try tekin europe: http://www.tekineurope.com/part-info.php?partNo=TT2283
There is a video on tekin's website that shows how to replace a sensor pcb.
Here you go: http://teamtekin.com/video_tech.html. Its the fifth video from the top.
@T$: that sounds like a sensor problem. Try changin the sensor wire or the sensor board on the motor. The motor is cogging because of the sensor.
Thanks!
Question for you racers. Last night while riding my sc10, my truck started shutting down after a few jumps. It took about 10 seconds to reset then power came back on. I didnt loose steering, just no throttle.
It only happen once in each race, but 10 seconds is a long time to wait, specially when everyone passes you after being in the lead. Anyways, is this a ESC issue or sensor cable?
Heres what im running
Tekin RSpro
LRP 9.5
Spektrum SR3300 Rx
Savox 1258 with glitch buster
Thanks in advance
Tekin RSpro
LRP 9.5
Spektrum SR3300 Rx
Thanks in advance
Tekin RSpro
LRP 9.5
Spektrum SR3300 Rx
Thanks in advance
Tekin RSpro
LRP 9.5
Spektrum SR3300 Rx
Thanks in advance
try a different battery and check your connections.
Any other ideas?
Ok, since it is a Spektrum, I had a similar problem when other 2.4ghz radios were stepping all over my signal and causing the my receiver to lose link. probably not the problem you are seeing. what settings are you using on the RS Pro? Does the motor lose all power or just slow way down?
Try a different servo. Make sure the wires aren't hitting the mode button when bouncing around.
Also, don't ride your truck, too much strain on the electrical system.
Yeah all cables are clearly out of the way... but may when I reset my esc when i sat on it lol.
I hear you on the spektrum, I was having little spurs of no response when the drivers stand was packed, but has not been an issue lately. All settings on my ESC are default except for im running sensorless instead of dual. I heard that was a better? I dont run any timing, 9.5 is quick enough. I loose all power to the motor steering still works though.
Chinese Deans knockoff connectors!
Location: Oreganastan Pacific Wonderland home to Indoor Farming
rs/rs pro offroad
Randy has made mention of this happening after said "slapping" of chassis on jumps............mount the esc more 'softly' with several layers of servo tape, or with quality hook n loop (velcro) type fastener , should not be 'shoo-goo'd in place!
This will help.
This will help.
'llo guys,
Have been out of tekin-tuning for a while as I raced offroad and don't need all that fidling there. Just a basic setup and it's up to my hands to fine-tune the rest.
But ... I would drive a bit onroad now. Hence my question: does the tekin rs pro have a blinky-mode, do i need a specific update for that?
Thx in advance!
Thx in advance!
