Flaw in new Futaba s9551?
So the Futaba s9551 final came out and I purchased one for my TC5. Its too wide. Just slightly. Anyone else had a similar issue? This is the first Futaba servo Ive installed in a TC5 so Im not sure if all Futaba servos are like that or just this one. I assume I wil need to hack it up with a dremel to get it to fit?
That sounds more like a "flaw" in the TC5's adjustability than the servo.
The Airtronics servos fit fine. Anything else such as KO or Futaba etc... need to be modified.
Later,
Later,
My Futaba fitted fine in my TC5, its a tight fit but no modifying needed
When I had my TC5 last summer, I had an s9550 servo. The s9550 and s9551 are pretty much identical, just updated innards for more torque.
What, come on now. I think the real problem is the TC5 chassis, I think they drilled the holes too close/narrow. Try mounting the servo aluminum stand-off's to the servo itself first. Leaving the screws through the stand-off's just loose enough so they can move a little, and then mount the entire servo/stand-off's on the chassis at once, then fully tighten the servo to stand-off screws.
