Team Magic E4 Thread
#2506
Hey wyd i have been running on carpet practicing for vegas and it seemed like my car would turn really hard initially, and felt like it was lifting, the 3* hubs give it ton of initall steering so i switche to 6* it made the car rotate more, and didnt lose that much steering, just could go down a spring rate and it would give you the steering back. You could always give that a try?
#2507
Tech Legend
Trader Rating: 51 (100%+)
I'm going to try some more droop in the rear and front and then look into getting some thicker front sways for the car as well. I run the stock 1.2 upfront now. Might alos step up in spring as well. I will mess with a few things next weekend.
My car steers great so I don't want to loose the killer steering I have so I will try a few things and see what I come up with. Most tracks you look for steering but at ares many times your trying to get rid of some. I took out 20% on my steering throw and still had killer steering.
I would like one smaller front piston for the car but don't know what others brand pistons might fit and I only seem to see one size for the car if I use factory ones.
#2508
brian, how was the car? how was the motor? novak not up to it?
R
R
#2509
Tech Legend
Car was pretty good again this week. Track did start to get a ton of traction like the old days and I have not run in that condidtion for about 4 years plus now so the car already had mad steering so it had more and wanted to traction roll if I wasn't careful. Overall still ran well. My car is almost too stuck as it is really glued to the track. New tires wore perfectly and the new Wold aluminum parts looked great and worked even better. Only slop is the whatever the bearings have and the ball cups and thats it. Very happy with everything.
I tried the DUO just to compare back to back with the Novak. I ran the Novak in practice and thru the first round. Ran the DUO in 2nd, 3rd and mains. It really wasn't any faster and my lap times between the two were almost the same. The Novak motor is plenty up to it.
#2510
Tech Legend
I have been thinking about this for a day or two but I think I will shorten up my front camber links for the first change on my setup. Car has a ton of steering overall and especially middle off with the 6 degree blocks on. Don't want to change alot up front so will go with the front camber link and work from their and see how it goes. I want to also see where the front arm sweep is set at? I guess it is either 1.5 degrees or 2.5 degrees like the stock rear toe in block.
John you still running your car at all or did you Photon finally make in in?
#2512
Not a bad day of racing. We had 23 entries in 17.5 today. I ended up qualifying 3rd and finished 4th overall so not a bad day of running with my E4 today.
Are indoor asphalt ended up getting so much traction since we had a large amount of racers today that I had some traction rolling issues. I had great steering today as normal but the high traction caused me to have a little extra steering and could traction roll if I wasn't careful. WIll work on that for next week. Still a great day overall. Car still was as quiet as ever around the rack and the tires made pretty much no noise thru the corners.
Do any shock pistons fit the TM shocks other than the TM pistons? Just wonder if anyone found anything else that works. I would like a little small hole piston for the car in the front but if something else fits the shocks cool but if not I will have to order some TM pistons.
#2513
Here is the link where I uploaded some pics from my country's RC forum, you guys may find some interesting setup and modification, check it out
http://s371.photobucket.com/albums/o...life2008/E4RS/
#2514
Tech Legend
I just checked my friend's post, he said the pistons can be used in E4's shock body and he used XRay's everything (shaft, pistons, end ball) with E4's shock body (check the link below).
#2515
Since this car has battery closely at the center and narrower chassis, it seems to me that the weight balance issue (right to left) has been minimized. Does anyone still add lead on the battery (lipo) if the race doesn't require min weight? If so, where do you guys place the lead to achieve best balance?
#2519
Tech Legend
#2520
Tech Legend
