CRC 1/10 Pan Car >
CRC 1/10 Pan Car
Like Tree3Likes
CRC 1/10 Pan Car
Old 11-29-2012, 04:55 PM
  #3031
sg1
sg1's Avatar
Trader Rating: 79 (100%+)
Originally Posted by scootr117
Why a 96 spur? Does the pinion change to keep the @3.23 roll out?
I remember somewhere hearing the relationship of the pinion to spur didn't matter if the ratio was the same. ie 44/88 should be the same as a 40/80.
I run a 96 on tight tracks, If "sbrewer" is running on a 45 x 35 track he's gonna need the speed off the corners on that little track.
As "BCBud" said, you can achieve the same rollout, but move the weight of the motor. I personally will only go down to an 88 spur and max of a 96.
sg1 is offline
Old 11-30-2012, 07:45 AM
  #3032
bkspeedo's Avatar
Wayne,
What front wheelbase are you running?
Wide, Medium, Narrow?
Long, Medium, Short?
bkspeedo is offline
Old 11-30-2012, 09:59 AM
  #3033
sg1
sg1's Avatar
Originally Posted by bkspeedo
Wayne,
Medium width plate, turned around backwards.
I have the a-arms mounted in the long position and inline axles.
sg1 is offline
Old 11-30-2012, 02:43 PM
  #3034
will your set-up work with the standard crc frontend (non long a-arms) and front servo reversed?also what size tires?
BullFrog is offline
Old 11-30-2012, 02:45 PM
  #3035
sg1
sg1's Avatar
On high bite carpet, no, it's too aggressive with the stock upper arms.
sg1 is offline
Old 11-30-2012, 03:32 PM
  #3036
bkspeedo's Avatar
Wayne,
Is there a benefit to placing the damper tubes up so high or did you move them up so they would not hit the wing plate?
Have you found any benefit to having damper tube flat versus angled?
bkspeedo is offline
Old 11-30-2012, 03:39 PM
  #3037
Well I've got the rear pod done. Now the shock- what weight oil.On the front end do I go back to the standard servo like the picture or will it work reversed. I'm asking because it took me awhile this morning to reverse it.If not I'll go back to normal. Also what size tires as Mick said anything under 2.09 was questionable? Getting the car ready for the birds.
BullFrog is offline
Old 11-30-2012, 05:38 PM
  #3038
Trader Rating: 16 (100%+)
Frank Calandra and Dumper told me 30 wt oil in the center shock for all setups. So, that's what I do.
Bill
Still Bill is offline
Old 11-30-2012, 05:43 PM
  #3039
thanks
BullFrog is offline
Old 11-30-2012, 05:44 PM
  #3040
sg1
sg1's Avatar
Wayne,
They were moved to so they wouldn't hit the side plates when I raised them to move the springs.
Then I tinkered with the tube angle and found the straighter it was with lighter lube the more linear it felt. When I got that feel the car rotated faster and had more chassis roll keeping the tires on the carpet.
At the local track I run just 1 tube with 20k in it
sg1 is offline
Old 11-30-2012, 05:47 PM
  #3041
sg1
sg1's Avatar
The only reason I put the servo in the position it is was I was trying different front plates and it was easier to keep the servo there and swap out plates
As for tires, I start mine at 2.08"
As traction builds I cut them down.
By the main at the Champs I was at 2.01"
sg1 is offline
Old 11-30-2012, 05:52 PM
  #3042
thanks- its time to finish the car.
BullFrog is offline
Old 11-30-2012, 07:01 PM
  #3043
Yes it is...And then post pictures...LOL
Bill
Old 11-30-2012, 07:32 PM
  #3044
where do you have the caster shims? I've got them 3 in the back.
BullFrog is offline
Old 11-30-2012, 08:12 PM
  #3045
I rarely have anything but 1 front/2 back. Carpet and asphalt.
Bill
