Tamiya mini cooper
#2026
I'd have to agree. The M03M is the best if you're starting from scratch for sure. The differences between it and the others are shown on our website. (its really only front suspension) But given that some bearings are included as well its easily the best value. And you can pull the chassis spacer out and you've got an instant SWB kit too.
Apart from the suspension and chassis spacers, all the M03 kits are the same.
#2027
Carpet race setup
hi, there. had any one experience with carpet race for m-03m? any suggestion for the best tamiya tyre for carpet race ?
#2028
M- Grip radials (50684) are our choice for carpet... We dont get to run on carpet very much but they seem to work quite well.
#2031
I'm sticking my neck out here, so here it goes. I have a M01 and a M02 and had heard that they were great for carpet tracks. My question is, what's the best set-up for Cinnci?
#2033
Nice job customworksking!
So what is the internal gear type of choice?
Stock diff or ball diff?
I'm looking for better pull off the line what works best?
Also what works best for the corners?
#2034
car
2.,3,4.stock diff put every shim you have in it so its close to locked that will help all around+ 1 of my motors
#2035
Putting loads of shims in will work, but will get you disqualified over here... Our rules state 'assembled as per kit'
#2036
hey guys... i am trying to set up another mini for a buddy here to run... but i dont remember what weight oil/piston to use on carpet? i have a spare set of shocks to swap around on mine, i just dont remember what i Put in them...
and an oring limiter count, if you know it... thanks!!!
Wes
Wes
#2037
Wes I maybe completley wrong but this is what mine is. 6mm spacer front with 90wt oil & a 2 hole piston. 5mm spacer rear with 70wt oil & a 1 hole piston. My springs I can't remember what they are exactly. I am pretty sure that is my exact setup. It might differ alot from what you usually run. Hope it helps in some way if not sorry.
Peace Aaron(W-W)
Peace Aaron(W-W)
#2038
Real Mini Cooper (Works Edition) racing an RC Car:
http://video.google.co.uk/videoplay?...92491462766951
#2039
Hey all,
Does anyone have a good carpet/rubber tire set-up for mini coopers??
I have short and mid-wheelbase coopers. Please PM me!!
#2040
Originally Posted by Static_racing
Hey all,
