Tamiya mini cooper
Hey guys,
I need some help. I ran these tires on my M-Chassis and they worked really, really fine and personally I like them more than the sweeps. Plus, they don't grab dirt from the carpet so there's no drifting around corners after a few rounds
http://www.rcmart.com/mini-radial-pr...?cPath=35_1086
Anyone knows where to buy them?
Or if the Pit Shimizus are equally?
http://www.ebay.de/itm/151195847197?...84.m1423.l2649
I don't have a lot of time with the mini and I'm not running it right now. My eight year old son is, an M05. He hasn't quite figured out that letting go of the throttle around the corners makes for faster and easier cornering. He hits A LOT of boards. The only thing he has broken on the car was the stock steering rack. We went witht the 3Racing version because it's available locally. Next I think will be the swing joints/CVD's. After that it will be determined by what he breaks. I really hope he doesn't break much.
you might be able to get those Much-More tyres from the UK Much-More distributor www.muchmoreracing.com
Yeah, they've got them listed. Double the price than at rcmart
Think I've to wait until rcmart gets them back in stock or try the Pits...
Thanks again
Like others have said, shocks and bearings are the biggest ones I've seen so far. Tires aren't an upgrade, they're a reality of racing. You need to find the best ones for your track. For our local series (WCICS) we are using Tamiya tires exclusively.
1.ball bearing kit.
2.oil filled shocks/w springs
3.When the rest break ill upgrade it if needed or get stock parts.
Thank you ill go from there if i need anymore advice ill ask the local racers first then ask all of you.
Happy new years y'all
tires for wooden floor m05
anyone now what tires work on wooden floor ,thanks in advance .
New Tamiya #42273 vs. #54000 and #84318
First post, very exciting!
I'm new(sh) to RC and have an M05 that I'm really enjoying. I've been researching dampers and was ready to purchase the 54000 when I ran into the 42273 ( can't post the url as a new member...see tamiyausa, rcmart, etc. )
These dampers appear to be relatively new and there doesn't seem to be any commentary yet, all I've really been able to find is "4 mm shorter than the standard 55mm touring" ( which would be 1mm longer than the 54000? ). What do you think, try the newer 42273 or stick with the 54000? The 42273 has an aluminum adjuster...anyone have any experience/thoughts...all the same thing?
Thanks so much!
Thanks so much!
Thanks so much!
Thanks so much!
I've hear of people cutting-and-shutting TC tyres to make them fit a mini wheel (cut a section of the tread out and superglue back together). Never tried it myself though.
Thank you for the help i made a upgrade list.
1.ball bearing kit.
1.ball bearing kit.
Thanks for the reply, I think I'll pick them up. There's mention of being able to use std. touring springs, is that a diameter thing or a length thing? Most of the recommendations I saw for the 54000 were for special short springs. This will probably all start making sense once I start playing around.
Thanks again.
Thanks again.
Thanks again.
Thanks again.
Quicky Question
What do you guys use to measure the temperature of an engine after
running a race?
running a race?
