Motor feels underpowered and jerky,
just got a new kit,
Futaba 2PH 2-Channel AM/2 S3003 Servos
Tamiya R/C 540 Motor
Team Orion Super Duty Plus 3000
Futaba MC600C ESC
while testing the electrics outside the car, the motor feels underpowered and jerky,
I have tried two different motors and two different batteries with no change,
I am 100% sure that I set up the ESC correctly,
any help?
Futaba MC600C ESC
any help?
Originally posted by Rod M
I am thinking that mabey the ESC is faulty??
Or they may have dead FETs, in which then the corresponding Fwd/Brake/Reverse function won't work.
600C is not reverse, right? (which leaves off the chance that your ESC is running 'reverse' when the motor goes fwd). Its not a locally-available model anyway.
Futaba 2PH (black wheel? this also not locally available) don't have endpoint adjustment, so you can't go wrong there either.
Well, you've already swapped batteries and swapped motors without any difference... why not swap in a different ESC too?
btw What are you using to charge your batteries?
Can you plug the motor directly to the battery, that should illiminate both of those things.
Carefull not to short out the battery though.
Tony
Tony
I an using a Eagle Racing CDC Ver 6.0/B Charger,
Tony
Tony
tested both batterys and motors and both are fine,
what else could it be??
Based on that it sounds very much like the speedy is not setup properly.
Have you gone through the speedy setup sequence? You need to set it up so that your radio and speedy think they have the same maximum speed and brake.
That is: When the throttle is on full the speedy knows it's full throttle and when the brak is fully on the speedy also knows that it's fully on.
Most speedie's have a one touch setup which lets you do that.
Anything like that in the manual?
Tony
Tony
Ok, so it sounds like it may not be setup properly. if he isn't getting full power through the radio but is fine direct to the motor.
So should be an easy fix.
