Capacitors for your receiver?
#16
thanks dirk, it takes a lot of time to keep in check but still i think its worth it.
sanj
sanj
#17
Regional Moderator
Originally posted by BrianJ
Talked to Novak,you can plug it into any open slot on reciever including the BEC slot.
#18
can y'all show me a pic of this? I had such a HARD time at a regional race this past weekend...GLITCH FEST SUPREME, heck I even went full speed into the foot of a corner marshall and got black flagged twice for glitching :P... I run the quantum comp. and a futaba s9402 servo with a XXL receiver... from what I've read, I think this could have been my problem cuz i couldn't find a single thing wrong with anything else!
#19
Here is a pic, I did it today..
#20
Regional Moderator
Are the capacitors wired in series or parallel?
#22
sanj
#23
Regional Moderator
Robo, yup alam ko, tagal ko na rin tinanong sa inyo ito kaso yun nga sabi niyo porma lang . Well no harm in trying.
Sanj, Thanks, how much capacitance is enough?
#24
it depends on how crap the bec of your speedo is and how much power your servo consumes.
as a rough guess i'd start high and work your way down. with my lrp quantum and modded homebrew servo i have to run 10,000uF but this is more than most people would need, so i would start at around 8000uF and work your way down.
sanj
sanj
#25
Regional Moderator
Ok, thanks. That's a starting point.
I'm using a Keyence Zero V Extreme (BEC = 6v/3A) with an Airtronics 94758Z servo (speed/torque = 0.06s/115 oz-in at 6v)
#26
Ortiz has 35V capacitors...I thought 10V was enough?
#27
addict,
your bec is probably good enough, if not a4700uf should be enough i reckon.
i did try a keyence speedo out and the bec was rocksteady.
dirk,
10v is enough, there is no advantage with using a 35v cap as it will be bigger and the voltage of the bec is 6v anyway.
sanj
dirk,
sanj
#28
At the time, thats all i could find...
#29
I have a capacitor for some time at the receiver of my RS4. Ever since I upgraded from an AM radio system to a Multiplex profi car FM system I had glitching problems. I tried changing the servo,receiver and even exchanged my transmitter at the hobbyshop. At some time I thought about spikes at the power to the receiver,so I tried a capacitor and then no more glitching.
Novak Dually esc
pico 4/5 receiver
Corally 12Turn motor
Novak Dually esc
pico 4/5 receiver
