LRP Pulsar 3
LRP Pulsar 3
Associated powered pulsar charger, discharger, charges 1 to 8 cell NiMH/NiCd, and 1 to 3 cell LiPo adjustable from 0.1-10A on the fly. Two charge modes: Linear and Flex with PCS-4 and adjustable Delta- Peak (5-95mV). Large extra-bright 2x16 character LCD-display with laser blue backlight shows all relevant data. Auto-restart system and auto start timer. Matching-mode fully automatic measurement of battery pack. Variable 0.1-10.0A Discharge current adjustable on the fly. Adjustable cut-off voltage from 0.9-7.2V. Powerful motor run in, (up to 14A) adjustable output from 2.0-7.2V. Breaks in brushes, runs comm lathes or powers 7.2V soldering irons. Adjustable voltage output from 1.0V to 12.0V/20A. Autostart-Timer, prgrammable from 0-99 min. 3 individual user profiles can be stored. Pulse width modulation for maximum efficiency. Program controlled cooling fan. Digital microprocessor operated
IS this charger to good for a New / Intermediat Driver.. I use IB 4200's .. so
If i needed a charger i wil buy a PQ3 !
Easy to use, compact design, state of the art tech features.
Lifetime warnty.
Get it !!!
Lifetime warnty.
Get it !!!
Same here. Actually got the MM as replacement for my decade old LRP P (still working great) beginning of the year. But sold the MM instead without using it at all and keep the old LRP P till today.
Now looking forward for the LRP P3. Firmly believe its the most user friendly charger out there in term of price & performance.
that is a good charger, outside of it not having a long lockout, it has everything. It charges lipo's great, it can do 1-3s and it is super reliable. It does a great job on nimh, but if you deadshort you will have to use the motor run feature to wake the pack up before you charge it.
Not a bad choice, I like it and the team orion carbon advantage and the team checkpoint charger.
lrp pulsar 3
does pulsar 3 have the motor break in feature?
lrp p3
yes it does have the motor run feature!
