Old 08-07-2006, 11:17 PM   #14581
Trader Rating: 17 (100%+)
Originally Posted by Tpg racer
Hey thnx man, may I know the price wise then??
How much is the difference???
tpg, you are in malaysia, i dont think you are able to get hara ed at the shop, i think they carry the 2005 version instead. get them they are better kit as well.
EngTat
Tamiya TB Evo 5
Spektrum DX3R 2.4Ghz, Sanwa ERG-VX, VFS-1
EngTat is offline   Reply With Quote
Old 08-07-2006, 11:39 PM   #14582
Lokanas's Avatar
Originally Posted by Nicadrauspro4
The Hara edition are equiped with these hop-ups:
a) 2.25mm CF upper deck which is stiffer (the original and v.1.1 have 2.0mm)
b) Upgraded competition threaded shock with teflon coated damper.
c) Aluminum servo mounts
d) Front solid axle spool (original and v.1.1 are using one-way axle diff)
e) Integrated one piece aluminum spur gear mount
f) Delrin rear outdrives (tougher than the original)
g) Quick motor-release motor plate mount
h) Aluminum camber plate mount (front and rear)
It's interesting, because mine HE has no aluminium camber plates, but it has one-way as well as spool included
Lokanas is offline   Reply With Quote
Old 08-08-2006, 12:24 AM   #14583
Nicadrauspro4's Avatar
Oh yeah. Sorry about that. I must have mistaken my typing. Ill edit it anyway. Thanks for the notice.
works1200.weebly.com
nicadraus-lamborghini.weebly.com
Nicadrauspro4 is offline   Reply With Quote
Old 08-09-2006, 09:21 PM   #14584
Justinian's Avatar
I was wondering if the Pro 4 is capable of holding the Orion 4800 platinum lipo packs?? It looked like in one of Orion's ads they used a Pro 4 as an example of how the lipo fit... at least it looked like a Pro 4....
Is the Pro 4 more or less durable than say, a XXX-S G+ ?? I only race stock and 19 turn in TC for the moment and was wonder what the strong and weak points of this car would be... (I'm looking at the plain Pro 4, not the Hara edition...) Any thoughts???
Justinian, Emperor and Roman God of Barrel-Rolls and Broken Parts...
________________________________________________
-Tamiya Evo V
-CRC T-Fource
-Losi XXX-S
-Darkside I-Force 10th scale pan car (under construction)
-Associated B4, T4
-Losi XXX-CR, XXX-4
"Evil will always triumph over good, because good is dumb!" :
-Dark Helmet, master of the Dark Side of the Shwartz......
Justinian is offline   Reply With Quote
Old 08-09-2006, 11:47 PM   #14585
rc-zombies's Avatar
Orion lipo should fit..
the Pro4 has extra parts that hold stick packs plus battery brace..
for the price of a plain Pro4... I'll sell you my Hara edition.
Old 08-09-2006, 11:49 PM   #14586
kewdawg's Avatar
The Pro 4 is a really durable car. It will break in the same areas as any other car. Stock up on steering knuckles, caster blocks, ball studs and suspension arms. If, you're using a one-way or spool, stock up on bevel gears.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 08-10-2006, 03:26 PM   #14587
Trader Rating: 46 (100%+)
Fortunately, I have not have to replace anything on it except for the bevel gears. I ran my Novak Brushless 4.5 and developed weird sound after the 2nd run. Apparently, the small gear in the rear diff was bad. I changed it but still makes occasional sound even though I have just designed that car for stock motor duties. Is it true that version 2 of the bevel gear is less prone to being chewed up? I am having trouble locating the bevel gear set at my LHS. Any suggestion or feedback?
Yellowtaro is offline   Reply With Quote
Old 08-10-2006, 07:57 PM   #14588
AngryAsian's Avatar
The new gears are different for both bevel, and diff gears.
The newer bevel gears are re-enforced to stop the diwely spaced teeth from spreading under load.
The diff gear is re-enforced on the back side of the gear to stop the entire gear face from flexing backwards under load.
The Ver 2 gears are much stronger than the originals, and should stand up to use with a 4.5 just fine.
If you have a large stock of v1 gears, you can purchase a CF backing plate to stop the gear flex.
AngryAsian is offline   Reply With Quote
Old 08-10-2006, 08:17 PM   #14589
GreaseMonkey's Avatar
I just got home from running my car for the second time on carpet. It's been a couple of weeks since the first time I ran and it took a little to get back into a groove. LAst time I started off on 1/2 throttle and moved to 3/4 throttle before a control arm was broken (not by me though).
This evening went well except for the fact that halfway through my 2nd pack and I clipped the wall with the LF which happen to make the RR wheel break. i replaced the wheel and when i drove it, the car oversteered badly. When I checked it, I found the front diff had come loose. I checked it and apart from a thrust ball missing everything seemed fine so I put in another ball and put it back together. What I want to know, is the diff loosening something that is fairly common and what can I do to stop it happening again? Loctite the threads?
I'm not a grown man playing with toys. I'm a hobbyist.
GreaseMonkey is offline   Reply With Quote
Old 08-10-2006, 09:30 PM   #14590
xray racer's Avatar
Trader Rating: 22 (100%+)
Greasemonkey,
The last time i ran my Pro4 i had a similar problem with the diff slipping all the time. Your best option, like you said is to loctite the threads and see how ya go with that. Might be an option to get the Heavy Duty nut aswell.
At one stage my diff actually became loose just sitting on my pit table... i have no idea how that happens but it did!...
I'm not really sure WHY it happens, it just seems to be a problem with the diffs.
See how you go with that,
Cheers,
Robbie
Robbie Lloyd
Yokomo * HobbyWing * Sanwa
xray racer is offline   Reply With Quote
Old 08-10-2006, 11:02 PM   #14591
Default wtb pro 4 shock tower
hey guys
Anyone in the San Francisco bay area have an extra rear shock tower they wanna sell me. I could use one asap and all the surrounding shops are out of stock as well as their distributers for at least a month. The car sucks as a shelf queen. thanks
ryan
rai13@hotmail.com
or pm me.
rai13 is offline   Reply With Quote
Old 08-11-2006, 12:00 AM   #14592
MikeR's Avatar
Trader Rating: 14 (100%+)
GreaseMonkey,
Are you guys by chance using the stock plastic diff halves? I'm using the machined delrin ones and have no real diff slip issues after the first adjustment after a rebuild. Maybe the stock plastic ones are expanding/ shrinking when your diff heats up/ cools down.
www.exotekracing.com ☆ASSOCIATED☆DURANGO☆HPI☆HB RACING☆KYOSHO☆LOSI/TLR☆SERPENT☆TAMIYA☆XRAY☆
A picture with your post, when trouble shooting, will probably get more rctech help than without...
MikeR is offline   Reply With Quote
Old 08-11-2006, 08:04 AM   #14593
rc-zombies's Avatar
Originally Posted by rai13
hey guys
ryan
rai13@hotmail.com
or pm me.
try Ebay...that's where I got mine...
Old 08-11-2006, 11:12 AM   #14594
Do you have the part number for the CF backing plate? Who makes it?
Old 08-11-2006, 11:17 AM   #14595
BillyCaldwell's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to BillyCaldwell
I have a couple purple pro4 suspension mounts, I think they are both 2.5, and a purple spool. I dont think it has been used, ill have to look at it again when I get home. If anyone is interested drop me a pm.
Thanks.
Maclin | VP-Pro USA
BillyCaldwell is offline   Reply With Quote
