Hpi Pro 4
Originally Posted by rc-zombies
the force is strong with this car..
and the purple makes you go faster...
anyone using futaba 9550 servo on their pro4?
About 2 months ago I got a used Pro 4, and like all the used cars I get I immediately took it completely apart. Well, after 2 months and several shipments of replacement parts I just got the drivetrain together my question is how free should it spin? Appreciate the insight!
It should be very free, the trick is to play with the shims on both diffs.
When the wheels are on, spin the wheels as hard as you can and the wheels should spin for quite a few seconds. Mine spin for 3 or 4 seconds, but ive seen a lot better on other pro4's.
Matt
Matt
And if you put your finger on the spur gear and turn it very slowly, you shouldnt feel any notches or rough spots in the drivetrain.
Matt
Matt
no wheel, no motor.. I spin the driveshaft and it should spin for several revolutions.
gearing
Could someone plz give me a general idea of what pinion I should use on the Novak 5.5 motor with pro4 stock spur at a medium size parking lot track? thanks.
Originally Posted by jamescam
I feel a lot of notches with the wheels off Any ideas on how to improve it?
bearings clean?
apply diff grease on the gears.?
Not only are the bearings CLEAN, but is one out of round? My friend took a hit in his TC3, and when we stripped it down and cleaned it, we turned the bearings and felt a few of the balls were definately ovaled. It gives it a super fast "pusling" kind of feeling when you spin the bearing.
-Josh
-Josh
Rear end loose
I just finished building my RS4, man is it fast. Only one problem, if I give it too much throttle the rear-end gets very loose. Also when I release the throttle it swaps ends. I haven't raced on-road in quite a while and I have no idea where to begin. Any suggestions? Thanks
spinning it with the wheel on is not good way. the wheel's centrifical force is doing the work. I can put a heavy wheel and it will spin idefinately.
Matt
