Hpi Pro 4
#8806
Which shock oil is recommended 2 run on asphalt? wat is the weight of the stock shock oil?
#8807
Originally posted by robk
"While both are really good cars, my opinion is that you took a step down changing from an Xray to HPI. Sort of like going from a Cadillac to a Buick."
Is this a pathetic troll attempt, or are you that easily fooled?
realistically at the top level xray is below tamiya and hpi.
dont get me wrong xray is VERY nice in all build attributes.
#8808
Originally posted by floodo1
umm just cuz the xray is $$ doesnt make it better. same goes for 415
In my opinion xray is right up there with tamiya. You open both these kits and the craftsmanship is just phenomenal. There is a reason why these kits are more $$$ because they are simply beautiful.
#8809
#8810
xray cars cannot be that bad i think some one said they had the most cars in the top 20 but hpi can't be bad either finishing 2nd and 3rd.
Chazz
Chazz
#8811
well, as a current owner of a pro 4, evo 3 and 4, 415, 414, Xray evo2, and a couple of cudas...
i do like the Xray, but the lack of fine adjustments of the rollcenters surprises me... you can only use the holes predrilled in the chassis. by using the other manufacturers setup, they are infinitely adjustable by however small shim you use.
granted, i dont think that i can fully utilize all the benefits...!
they are all excellent cars, fully capable of winning. i wouldnt say that any car is necessarily above or below, just drive what YOU like, and let 'em all eat cake...
#8812
Well said!
#8813
i wasnt dissing xray, i was just saying at the TOP LEVEL their performance is generally less than hpi/tamiya. that is that hara / reinhard + the rest of their teams, do extremely well in a-mains, and making a-mains.
as chazz says xray is able to put a lot of cars high up (top20).
and duh xray has the nicest car based on quality of parts. their spring steel and aluminum are top notch.
for the typical race the car that is going to be the fastest is the car they can get the most help with.
and if you dont need help with your car in order to be fast, then sponsorship determines what car you drive! (more than likely).
#8816
Originally posted by FW05R
saying that xray is below tamiya and hpi is just your personal opinion
About Tamiya/HPI doing "extremely well in a-mains, and making a-mains" is a little due to the drivers they have... they have world champs on their team so that's why they are in the A mains more than the lesser experienced teams...
#8818
same number as the rear diff
#8820
does anyone know when the hpi spools will be available?
