Hpi Pro 4
#7171
Originally posted by Eirik
Scott,
I just ordered 1pcs of the Excel part, just to see what it was.
It included 4pcs of the graphite spacers, two for front and two for rear. I think Hara was using the same parts at the ROAR Nats.
The 2mm washer under the steering link ball stud is located out by the hub, this will do the oposite of lowering the graphite steering plate. Again this will make the car more predictable and easier to drive!
Tip: Make sure your diff outdrives are in good shape, when they are worn you will loose steering and rear traction!!
The Delrin diff will make a big difference + it last allot longer!!
Good luck at the KO Race, I had plans to go there, but I have other commitments that weekend.....
Cheers
Scott,
Cheers
Thanks will try that 2mm washer on the hub. I am using the delrin diff outdrives with associated diff screw, t-nut, spring etc.
Thanks I am really looking forward to it .. pity you can't race cos it is apparently really good. Will let you know how testing goes ... I can't wait to try the changes.
Was looking at the old 22's I stripped off my car last night and one of the rears had come unglued from the rim ... that was also prob part of my problem ... what a muppet I am I didn't even check during finals...
Anyway my new sets of tires and inserts and wheels should arrive today ... Most of my old ones went in the bin last night.
Cheers
Scott
#7172
can someone provide us (me ) with the hpi derlin outdrive product number for rainbow ten if they have it? .....or just the product number will be fine. i'm too lazy to fish through the rainbowten list of products
#7173
#7174
Originally posted by acutts
75169 HPI PRO 4 DELRIN OUTDRIVE SET
#7175
Scott,
The Graphite shaft is really good, there is no vibration from the drive train at all...!
With the stock shaft you can feel and hear the shaft vibrating!
I know it is expensive, but I think it is worth it and it will last forever.
Maybe I can make it down to England next year, we will see!
At WLRC you might want to try a spool since the track is really small and low traction.....
#7176
Gearing on carpet
For those that have ran the car on carpet, Mod motor, what kind of temp. is your motor running?
I ran a Reedy PT 10x1, new tires (61mm ?) geared at 98/25 and the motor was a 150*. A little warmer than I like.
Our current layout is super tight, almost all hard on the throttle, off and on again. Not much room for the motor to wind out.
take care
john
take care
john
#7177
Aluminum knuckle arms
Does anyone know the other manufacturers who make the aluminum knuckle arms for the Pro 4? I know GPM Racing and Jet Racing make them, but I forgot who else does. And also, which ones are the strongest? Thanks.
#7178
Racer, try the handy dandy KevinK setup. Works great.
"Ok here is a setup to start with on Foam tires carpet.
Front
#3 pistons
45wt oil
HPI Pink Springs #6759 30.2 LBS Or Losi White 30 lbs
1 Hole in on the shock tower from all the way out
Inside hole on the lower arm
1 deg toe block
2mm shim under the rear front block
1.5mm shims under the front block.....Anti Dive for the front arms
6 deg castor blocks
1 hole for akerman plate
Forward hole on the steering knuckle
Inner hole for upper ball stud....1mm under ball stud
Black Sway bar....1.6mm with 2.7mm showing on the tips
Rear
#3 Pistons
40wt oil
HPI Red Spring #6754 24.2 Lbs Or Losi Black 25 lbs
All the way out on the rear tower "stood up"
1 in on the lower arm
2 deg toe block
1 mm shim under rear rear block
1.5mm shims under front rear block....Anti-squat in the rear
**this is for the PRP chassis, where you have an extra wheelbase adjustment. Just run your car as long as possible***
Standard location for for arms as far as wheel base goes....this is a track dependent adjustment. Play with it and see how you like it
Rear hub stock spacing....big shim in the rear
Hub ball stud on the inside hole
Inner ball stud on the inside hole
.75mm under inner ball stud
Silver sway bar....1.4mm with nothing extra past the link
5mm rideheight all the way around......
Tires TM Racing Plaid2's and Magenta's 2.30"dia
33/104 with Binary Stock motor with 100 ft Straight
Losi Alfa Body
If there is anything that I missed or messed up just ask ...lol.
Front
#3 pistons
45wt oil
1 deg toe block
6 deg castor blocks
Rear
#3 Pistons
40wt oil
2 deg toe block
Losi Alfa Body
#7180
Re: Aluminum knuckle arms
#7181
Scott,
Scott,
I am off to try the new car setup this evening ... that is if it doesn't rain like it looks likely to do.
I have a homemade spool that I will take and try in practice, wish HPI would bring out a spool .... I heard they were going to release one soon but since then have heard nothing ....!
Yip the KO is definitely worth a trip ... that is if it doesn't pour.... I must try to get over to Europe sometime ... you guys have some awesome tracks ..!
Cheers
Scott
#7182
Titanium Racing are releasing a spool for the Pro 4 with delrin outdrives, available from CML, ask your LHS...
#7183
#7184
How many people have 2 Pro4's? I bought a second kit a while ago as a spare but have never got round to building it.
Thought it would be useful to have a spare at the track but now can't really see the use ... ! Setup would be different and I wouldn't be able to afford all the Hop-ups I have bought for my race car?
Anyway just asking generally if there are many people that have 2 of the same car
Cheers
Cheers
#7185
Re: Re: Aluminum knuckle arms
Originally posted by DOMOisCOOL
Square Racing also makes some. You can find some and more at www.allspeedhobbies.com
people i know usually use the second car for parts if they have one, perhaps its cheaper?
