Like Tree6Likes
Old 07-17-2004, 08:38 AM   #6181
Geetoo's Avatar
Send a message via AIM to Geetoo Send a message via Yahoo to Geetoo
Originally posted by rc-zombies
Don't buy GPM products .... you'll regret it later on... they use a very weak alloy.
Herd that gpm manufactures their stuff without "r & d", hence they are not race proven. I'd prefer Square instead.
www.hpiracing.com
www.hotbodiesonline.net
www.nosram.com
www.team-durango.com
www.actionhobbiesonline.net
Geetoo is offline   Reply With Quote
Old 07-17-2004, 11:08 PM   #6182
rc_square24's Avatar
Default GPM
im not sure about now, but when i had parts from gpm for my micro and the pro2, some parts virtually dont fit without sanding or they "just wont fit", and some alloy parts are not even tapped at the screw holes.
if youve used thier oil shocks youll know what im talkin about. they use black orings and molding of piston is poor, alot of friction.
not all thier parts are bad, and they might have improved now but just b careful when choosing from GPM
much better alternatives are Square from Japan and some good ones from HK are jet racing, 3racing.
rc_square24 is offline   Reply With Quote
Old 07-18-2004, 07:54 AM   #6183
infrontracing's Avatar
So does Square make alum. knuckles for the pro 4?
Or anything else for the pro 4 for that matter?
Losi 8ight E, Jammin scrt10, Blitz, TEKIN, Castle, Novak, Futaba 3pkS, AKA
infrontracing is offline   Reply With Quote
Old 07-18-2004, 08:00 AM   #6184
racer's Avatar
yes, they do. here's a link:
http://www.rc-square.com/parts22.htm
racer is offline   Reply With Quote
Old 07-18-2004, 09:31 AM   #6185
rc-zombies's Avatar
I don't recommend the Square alum. front knuckles...they tend to break near the area where it screws onto the C-hub... get the Jet Hobbies version... or soon to be released version from HPI which is offset about .5mm to improve handling...
Old 07-18-2004, 09:51 AM   #6186
who has the newer 1.1 gear instock and the backing plate.
Had a sweeet run going hit a pipe crunch crunch.
Thanks in advance.
sportracer is offline   Reply With Quote
Old 07-18-2004, 01:20 PM   #6187
Send a message via AIM to Proteus
Default Re: Version 1.1 gears cont....
Originally posted by JDM_DOHC_SiR
Hey guys I just pic`d up a set of the new Version 1.1 gears..and I have some good andBad news for you guys... the Good news is that they are really beefy around the outer edge of the ring gear...and the bevel gear seems to be a bit re-inforced to.. Now for the Bad news.... All of you guys that have the PRP Brace....... for the one way gear,,, it "WILL NOT WORK" with the newer Ver. 1.1 gear You have to use HPI`s backing brace ( I wondered why HPI`s brace was a bit smaller a couple of days ago when I was doing some testing with the PRP vs HPI backing ring )
So for you users of the PRP brace..I would suggest you stock up on older bevel gears...If you can find them that is
and ALso the newer Pro4 kits here in Japan are now shipping with the Version 1.1 gears and Backing plate ...wonder if the States will be soon to follow
-Dave
Are you getting your parts from one of the shops in Akihabara? Would you mind picking up some extra parts for me while you 're there? My brother lives down in Yokosuka, but it's a pain in the a$$ to get him to run all the way up to akihabara. I don't blame him though. If I remember correctly, I took about an hour and 15 min or so and that's including changing trains in Yokohama over to the Yamonte line.
Proteus is offline   Reply With Quote
Old 07-18-2004, 01:42 PM   #6188
kewdawg's Avatar
Default Re: drive shaft
Originally posted by k.fellowes
hi boy and girls , i just got my 2nd pro4 . when building my car i find that i did not have MIP but had dog bone's eek: , has any one had the same thing but we are getting MIP .
Other thing's different are the shock tower's.
IRS
MY TOYS racing
HPI PRO4
YOKOMO drift car
NOVAK
Are you sure that's a Pro 4, you have? Did you buy the kit sealed / unopened or second-hand? If, second-hand... then it sound like someone played the "swap-out" game.
Quinn Moon
Trinity / Epic / Revtech / VBC Racing USA / Mugen Seiki / Hot Race Tyres / SkyRocket Racing / SUPAFAST RC
kewdawg is offline   Reply With Quote
Old 07-18-2004, 02:43 PM   #6189
JusBox's Avatar
Default Re: Re: drive shaft
sounds like a pro 4 kit from japan. they came with dog bones.
JusBox is offline   Reply With Quote
Old 07-18-2004, 04:13 PM   #6190
whats the link to Jet hobbies?
Old 07-18-2004, 05:15 PM   #6191
www.jethobby.com
Old 07-18-2004, 05:36 PM   #6192
kits in japan now come with universal driveshafts, unlike MIP CVDs they have the joint on the bone instead of the axle.
how are the shocktowers diff. from tthe previous ones?
Old 07-18-2004, 06:10 PM   #6193
JDM_DOHC_SiR's Avatar
Trader Rating: 31 (100%+)
Ditto WEAK..junk.. the the regular part is stronger
Ȼ4.5 Centro+α ◊ TRF 501ӽ ◊ TRF 502ӽs ◊ TRF 503 ◊ TRF 511 ◊ TRF 201ӽr ◊ TRF 211ӽ
B5m ◊ T5m ◊SC5m ◊ B64deez nutz
Speedway PAL ◊ SDRC ◊ Shop UFO ◊ SMC
JDM_DOHC_SiR is offline   Reply With Quote
Old 07-18-2004, 06:13 PM   #6194
The shock towers are still the same.... but some of the drivers in Japan prefer to use a rear tower up front also
-Dave
Old 07-18-2004, 06:38 PM   #6195
Send a message via Yahoo to Doug Gaut
Congrats to HARA and the HPI team for a job well done at the nats!!!!! Keep up the hard work ERIK!!
Doug Gaut is offline   Reply With Quote
