SpeedMerchant Rev 5
#436
I use the Associated 12R5 aluminum servo mounts.
https://www.ssl-stormerhobbies.com/c...=ns&pn=ASC4630
They are short for the mini servo's used in 1/12, allowing you to use both screw holes on the left and right of the servo. Yes, they use "metric" screws, but it's not like there aren't any other metric screws in use on the car. Part of the Silva shock included in the Rev.5L uses a 1.5mm set screw.
#437
what you will want to do then, is to drill the holes for the servo mounts and then shift the 9650 around until it line up. if you don't prep for the servo mounts now, you will need to buy a new chassis when you are ready for it
#438
#442
#444
The asc offroad (t4/b4) mounts are standard hardware. Can't use all 4, but not really that big a deal. Just use cut #4 washers on the screws. My guess on the ones Dumas is using would be GPM ones (ala these: http://www.hobbyetc.com/cgi-bin/item...#ilikepictures)
Biggest thing I've learned when mounting a servo by drilling is line up your servo front to back within the little pocket in the chassis and then measure the distance from the front of the chassis to where the screw will go in the servo mount. Lock that distance down in your calipers and scribe a straight line so that both your servo holes will be the same distance from the front.
#445
#446
http://www.niftech.com/catalog.php?mode=3000
near the bottom of the page. but I run titanium lower screws from lunsford. they have no lip to them so they sit a flush with the bottom of the chassis.
#447
Few Pics with the Thunderpower pack....fit is sweet
#449
Booster
