charge settings
charge settings
im currently charging my gp 3300s on a cell master platinium and think im doing someting wrong as my batts are only peaking at 2100mah
4.5a
delta peak 3
temp cutoff 48 c
cutoff 3800
thanks
4.5a
delta peak 3
temp cutoff 48 c
cutoff 3800
thanks
Are the cells warm after charge? If not, try using the long lockout function on cell master, set it to like ~25 mins or so. If they are warm after charge, I would recommend looking up new cells, these are a bit outdated anyway..
make sure you have the batts discharged enough before you charge them, you can also try increasing delta voltage.
thanks for the info guys ive whaked my delta peak up to 7 and they are only false peaking right at the start and are now peaking at 2600
thanks
thanks
