Tamiya F103 Forum
#2206
Hey maybe someone can point me in the right direction.
So I got my box of parts yesterday for the F104 front end conversion and I'm also going to use the F104 rear end as the upgrades are readily available and F103 parts are hard to come by.
Here's my question, the screws that the F104 uses are all different than the standard ones used on the F103, I didn't see this mentioned anywhere in the conversion posts or what part kit is needed for this. I'm also missing the long screws used to go through the bottom of the chassis, A arm and into the ball studs. They're long screws. Also a few short screws that go into the ball stud ends.
#2207
Here are the screws you'll need:
#2208
Thanks, I have the kit manual but I wasn't sure where I'd find them at
#2209
These will work, the Tamiya ones are harder to find.
NEW Traxxas Screws 3x36mm Counter Mach 3172 | eBay
#2210
#2211
Thanks for the info! I started googling part numbers and began to notice that these fasteners aren't all that special, all are M3 screws of varying lengths and head types. I'm going to source my local hardware store and/or order them on ebay/amazon. They are MUCH cheaper than ordering Tamiya parts and I can have them in a couple days here in the states. Although I was mildly surprised how quick RCMart's stuff got here from China. Huge A+ to them and their quality service.
Mark
#2212
TQRC works for me as it's local, but Amain Hobbies is also pretty fast, they're in California so I usually get my orders within a couple of days. I'm starting to like the ProTek titanium screws that Amain carries.
#2213
I've also had stellar and fast service from TQ Racing, I try to order my stuff from them but the F103 parts tend to be more readily found overseas
#2214
And for the M4x30 I went to the local hardware store and got some steel ones instead of the weak Tamiya Alu screws.
#2215
I actually was quite lucky and was able to find a wide assortment of M3 sizes at my local hardware store today. Also steel I believe. I've got the car assembled, just need to get some new E clips for the F104 king pin assembly and glue up the tires
#2217
you could use tamiya diff grease , or even general diff oil around 3k to 10k depending on the grip.
#2220
The wolf is on sale at Tamiya USA: https://www.tamiyausa.com/items/radi...wolf-wr1-84124
