GM Brushless
#2446
I'm using Martin's settings.
#2447
but you haven't changed any timing? and switch point?
#2448
I run 25 fixed timing and 26 max timing and without switchpoint Reserved 4=1.
#2449
hello this is just my opinion from what i have found through my testing. There is 2 ways to gear the car, one is with a low fdr (4.6 or so) and the other is with a high fdr (6.0 or so). Both of these may have similar speeds but acheive that differently, one through high rpms due to the motor being aloud to reach a higher rpm because of the higher fdr (6.0) or the other due to the increased rolout of the car on the lower fdr (4.6). I personally run on a large open outdoor track with 10.5 running 25 degree fixed timing and a 10k switching point, and i am geared at 6.5. This achieves very good bottom and top end speed. What i am trying to say is you should experiment and try a gearing in the other direction and see how it works for you.
#2454
Hello,
Can anyone tell me if the GM genius 95 can make 3.7v LIPO batteries?
It's for a 1/12 chassis, I have tested it just in the pit and the controller switch on but I don't know if the controller is OK on the track during 5 or 8 min.
Regards,
Adrien.
Regards,
Adrien.
#2456
I use GM PROstock 10.5 motor with 12.5mm rotor. I have tested it without the booster/rx battery but the speedo switch on. My GM 95 have the v4.8 .
I have a GM 75 but I use this on my Xray T3'11 and I want to drive with my 1/12 chassis too but my touring car season is not finished...
#2457
Any one got any ideas on this?
Same speedo GM, same motor, same gearing and car, same profile, everything the same but i'm running motors 20-30C hotter. Any ideas why that would be?
Tried different motors to eliminate that but can't work out why i can't get anywhere near other peoples gearing or timing. My mate for example with the same kit is running 15 degress more timing and is coming of the track at about 85c. His car has more punch the hole race and feel like it could be pushed even harder. I'm hitting the overheat amp limiter set to 120c about 3 minutes in.
Is this down to driving style. Bad speedo or capacitors on their way out?
#2458
If thats ok and you've already tried different motors then I would see if the caps are to blame. Is the speedo getting very hot as well?
#2459
Have tried a reset in the past as well as copied mates profiles and no difference. Speedo is running at 73c on 13.5t carpet without fan.
I know caps give a lot of punch to speedos but what is their main purpose?
#2460
When you have finished your PC set-up, you can re-calibrate your mode to be sure your speedo can work good.
