CheckPoint 19 Turn >
CheckPoint 19 Turn
CheckPoint 19 Turn
Old 08-12-2007, 06:56 AM
Trader Rating: 11 (87%+)
Default CheckPoint 19 Turn
I cant seem to find the Rpm's for a new checkpoint money motor 19 turn
any ideas
srs64 is offline
Old 08-12-2007, 12:51 PM
bs6ef's Avatar
the rpm is obviously dependent on the Voltage it is tested at, i last tested my motor on my dyno after the rebuild and got around 19500 rpm @ 4.8v, can't remember the amp draw..... This was using the atlas brushes with a hole drilled in the centre running medium spring on P+ and soft spring on the N-, and on the track in my sp12x it was awsome running 46mpr on a small track.
why do you want to know the rpm?
any ideas
bs6ef is offline
Old 08-12-2007, 01:11 PM
trying to do a exel sheet and needing a rough I deal to get MPH
srs64 is offline
