BMI's DB12R
#7426
What is the general difference between mounting the servo flat or angled?
#7427
[QUOTE=protc3;5903907]Hey guys,
I looked into the rear flex plate pivot housings and didnt find anything unusual about them. They are the same as they have always been and seem to be the same strength as our origionals. However, i will increase the wall thickness around the pivot balls being that there are some of you that are having problems with breakage. I will be making the new ones as of monday and will throw away the inventory i have now. The center pivot will not go through any changes as we found by strengthening it moved the breaking point to more expensive areas of the car. The rear pod took too much abuse when i beefed up the center pivot.
I was surprised to hear about this problem until it happened to me twice?
My research shows the fault is not the pivot housing but the set up! To light, and in a corner the rear slides the back end into the boards everytime with the new light weight 1s lipo.
For sure, without the weight of the 4 cells the back end unloads really quick and slams the rear wheel flat into the boards. The impact moves directly to the pivot ball in the housing. Believe me I've test the strenght of this car.
#7428
i thought you had suggested using the servo in the fwd position with the ball studs behind the horn (arms go between the horn and servo)
do i grind some material from the servo support or ?
#7430
sorry, i still don't get it. if i try to mount the servo in the forward position, the servo body foul's on the lower arm.
#7431
#7432
I've ran both the CRC and the Serpent and like both. However I did have some alignment issues using the CRC with the long upper arm conversion. Another driver in our race who runs a BMI also runs a CRC and did not have the same alignment issue I had. To be honest though as long as you are careful in the build (Get a 8-32nd tap!) the stock front end is as good as either of them. Next season the guy running the CRC front end is going back to the stock and I have some ideas that I will be trying with the stock front end as well. My suggestion would be...if you are just looking for performance...stick with the stock front end and learn it well. There are a lot of little tricks to learn that make it work better. But if you are like me and like to tinker just for the sake of tinkering then by all means try another front end.
#7434
Jason said that it'd be 2 weeks before the chassis' are ready 3 or 4 days ago. I would guess it's going to be a little while longer. Maybe he wants to post pic's of the production chassis and not the test mule.
E
E
#7437
when can we pre order?
#7439
bump
maybe a shot at a picture??
