Tamiya TA05 IFS
#526
Hi all,
just a quick check for all IFS-R out there.
Anyone using Novak XBR 8.5 BL system and the gearing range?
I am using 105/34 now.
DOes anyone else uses a different setup ?
Thanks ya.
Thanks ya.
#527
I just stopped by my job and we got out order in. I ordered a body for my IFS-r. I got the Tamiya Raybrig NSX (part #51306).
I am going to clean and paint it later today. Tomorrow I will apply the stickers. There are alot and it will take some time. At least they are all pre-cut. Tamiya saved me a few hours there!
I will update with pictures soon!
#528
I cut and painted my body this afternoon. I just got finishing applied decals to the left side and, front end and hood. Tomorrow I will finish it up and post pictures. Looks great so far!
#529
Since P-Dub is MIA, what are you guys doing for a more solid bumper?
#530
NSX body is done! It looks great. Just attached my wing. Only thing I have to do is paint and mount the mirrors.
Pictures tomorrow!
Pictures tomorrow!
#531
I finally took pictures of my car.
Let me know what you think!
#532
anybody want a IFSR. ran at TCS (Maryland) then has sat on the shelf since. has a spool and other spares. also have new TA bodies, wheels, and tires if some1 is interested in runnin it there. lemme know.
R
R
#533
#534
carpet woes
any body have any setups for the tao5 ifs R for carpet
#536
My TA05IFS
#537
Very nice CF chassis conversion for your IFS! Pretty similar to what I have..
I have a IFS converted to a Kawada CF chassis, what's this one that you use?
It must be a very nice drift car!
Sincerely,
Den
Sincerely,
Den
#538
Mine is Xenon Racing... Ya, it drifts very nicely... very balance chassis...
#539
R/C Tech Elite Member
Hey guys wondering if anyone can help with set up suggestions for this track:
http://maps.google.com.au/maps?f=q&h...03433&t=h&z=18
It's an ex nitro track, now electric so fairly large, at the moment my TA-05IFSR is set up as:
2 degrees neg camber
1 degree toe out front
2 degree toe out rear
Yellow springs front, 35W oil, 2 spacers on rocker arms
Red springs rear, 35W oil, inner most suspension hole.
6mm ride height
3mm droop front, 2mm rear
No antisquat / kick
factory roll centre heights
Factory settings for wheel base, although I think maybe taht should be lengthened to settle it down a bit?
Running:
LRP TC Sphere
Trinity 10.5 Brushless
S9551 Servo
IB 3800 Lipos with 20 grams weight on top of battery
Jaco Blue Rubber Tyres
Honda Accord Shell
Race weight is 1509 grams.
I am finding it is liking to push a lot into corners and the rear can then break loose. As such I am 1-2 laps behind the pack by the end of it with offroad excursions etc. Need to get some help!
6mm ride height
No antisquat / kick
Running:
LRP TC Sphere
S9551 Servo
Honda Accord Shell
#540
Hey guys. Im in the process of building the TA-05 IFS kit and have come across a problem with my servo being too big to fit in it's place on the chassis. The servo i have chose is a Hitec 311 which i believe is standard size for most servos. So my question is if i will have to trim some of the plastic off the servo ears in order to make it fit, or is there another way to solve this issue. Thanks as always guys.
