Alex Racing Barracuda R2 & R3
Originally posted by wyd
I would like to run my spool more but it really tears up my idler gears if I hit anything. I know a spool would be faster for me but I get tired of changing out the gear.
Ran with the spool today on a high bite high speed asphalt track in L.A. Car was so dialed in 19turn that It won the a-main too... although I had a little help because the race program ran late and the TQ's car was too dark so he got stuck on a pipe or something to let me sneak by. That's why I always run with atleast 1 flourescent color in my paintjob.
So shimming the idler tighter doesn't help any? Even if it might be a little louder?
Mounting shell on R3
I remeber JDM_DOHC_SiR said something about using a Protoform Mazda 6 body, then the 2 rear body post need mount on the front of the rear plate..
Just want to know which body shells dont need to change the setting of the mount pole (from the manual given mounting position) ???
Will the Tamiya B4 body ok with it??
Its not a big deal to switch the posts around.
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by MikeR
Really? That's too bad. I haven't had any problems with the gears...yet...
because I need to mount my rear damper on the outermost hole,.. so if i swith the body mounting pole to the front... then the damper will blocking the way, and hence i cant mount the body pole in the front of the rear plate....
thats why i need to find out which body will fit it... with out blocking the wing.
Tech Legend
Originally posted by chappi
no.no..
no.no..
Re: Mounting shell on R3
-Dave
hey dave u tryed the rayspeed accord? or have any news about its handling?
Re: Re: Mounting shell on R3
Originally posted by JDM_DOHC_SiR
You really should try out the New ALEX M6 Body then.... handles like the Proto Mazda...and also the Ride MKII Status.. since it kind of a blend of the 2 bodies and you will not have to worry about the Body posts being switched around..
-Dave
-Dave
Just finished of shimming two bevelgears in alu- shaftholders for a friend We'll see if it works with a little less noise
Your high-grip setup post works very well with minor modification on carpet btw
-Dave
Re: Re: Re: Mounting shell on R3
Originally posted by stjerno
Guess I have to try one for my next paint order If I ever gets to see the first one Did you ship it by banaboat ??
also good to hear that the R3 setup works on Carpet too .. it"s a really stable good set up that I like to run
-Dave
Re: Re: Re: Re: Mounting shell on R3
This week you should have all 6 of them
-Dave
-Dave
Oh.. I'm running 4 deg of toe in the rear .. should I go down to 3 .. 2 ??
Re: Re: Re: Re: Re: Mounting shell on R3
I got the PAL steering rack installed in my R3 and finaly got all the steering I could ask for Now I'm not going to take any steering away for now (just got it ) but I think I'm scrubbing to much speed in the corners .. any ideas ?
-Dave
anybody do any modification on bodyposts mounting? Saw some drivers remove the rear bodyposts from rear tower to chassis directly. I suppose this for less body roll??
No pics...
No pics...
No pics...
No pics...
-Dave
