Yokomo MR-4TC SD
thank
THANYOU FOR SHOWING ME
spur gear
Hi guys, can anyone tell me whats the biggest size spur for both 48p/64p that i can fit in? Its for the SSG version. Thanks alot.
Hey guys what's the proper technique to measuring/ adjusting droop with the shocks and tires on? And should that measurement be the same with the shocks and tires off?
- JB
- JB
- JB
- JB
Re: spur gear
I stacked an 85T/48p and a 112t/64p together and they have virtually the same diameter. So I think if the 112T fits (only two teeth bigger than my current) then 85t might be your biggest 48p gear.
Re: spur gear
- JB
- JB
Done with my Rebuild!
Top View
Done With My Rebuild!
Front and Back
Last one. Showing off the TRF shocks, which has hassle free adjustments with your droop and ride height. And the Team Suzuki Rear Hub, which was a pain to find! (got it in a swap with 2 used stockers, alm input shaft, Springs & alum drive cups) BUT WAS WORTH IT!!
Now I have to get my hands on the new rear hubs!! I know so much unsprung weight, but I think the Ti driveshaft and bones will make up for it.
Weight
Lem2 - How much does it weigh, with batterys, shell and tyres. My CGM is almost an identical config, but I don't have a good set of scales .....
Yea... I'm curious too....
My CGM (without a body) weighs 1465 grams.... That is with... Tobee aluminum center shaft, dogbones, swaybar mounts, Suzuki front and rear aluminum hubs, Square titanium axels and input shafts, Titanium screws, Modded BRP front bumper, BRP nerf wings, No rear bumper or sway bar, modded steering with lunsford rod and dubro captured ball ends, rpm ends on the rest of the car, Novak GT7, Xxtra and Futaba S9550....
That should give an idea, I'm pretty close to him and think you are close to both of us.... Oh yea... Jaco's cut down to 27mm in front and trued to 59mm currently....
Re: Weight
BRP makes Nerf wings for the CGM? where di you get those?
They don't.... They are TC3 wings modded to fit....
Oh yea... I have the front and rear Yok aluminum suspension mounts....
I'll see if I can snap a picture.... My son just woke up.....
Thanks rough51 and ritchie.
Cause i'll probably be using it with a 23turn motor and a gear ratio of about 6:1.
Dont have a fleet of pinions to use with.currently have 48p-24t,25t,30t,31t,32t,33t--64p-10t,21t,22t,23t,24t,25t,26t,31t. Used those when i ran the x-ray and 12th scale.
Tried with a 48p/80t spur and 31t pinion today, seems like the motor will not fit the motor mount for optimum gear mesh. If it could, the motor will be way off the centre of the car.
So i guess it will be 64p 98t spur with 38t pinion for a 6.07:1 ratio. Btw, will be using Kawada spurs and pinions.
